20 Most Recent Compaq iPAQ Home Internet Appliance IA-1 (178358-001) PC Desktop Questions & Answers
2answers
Installing the compaq home internet appliance
does the appliance have a dchp ip address option or auto ip address option. The IP address is used by the wireless network to identify each computer device in your house. In your wireless router there will be a dhcp server that will lease out ip addresses to devices automatically. the ip address would be 10.0.0.1 for your router or 192.168.0.1 usually most used ip addresses . A subnet mask is usually 255.255.255.0 which is also needed. Go to your desktop computer and go to command prompt . Google your version of windows and command prompt to work out how to do this. then type in ipconfig press enter key note the default gateway address and the desktop's ip address you may need to enter the default gateway ip address into the fridge also. if the desktop was 10.0.0.2 subnet mask 255.255.255.0 then make the fridge if manually have to set it 10.0.0.254 subnet mask 255.255.255.0 or 192.168.0.254 subnet mask 255.255.255.0 if it is 192.168.0.2 the first three numbers are called the network address eg 192.168.0 10.0.0 the last number 1 - 254 are individual address part 192.168.0.1 {router uses this 1 usually } to 192.168.0.254
1/16/2018 5:45:55 PM • Compaq iPAQ Home... • Answered on Jan 16, 2018
Need member id for msn companion
If you have purchased it, you have the ID
3/29/2012 3:57:28 PM • Compaq iPAQ Home... • Answered on Mar 29, 2012
Need hack for compaq msn companion member id codes
This forum does not provide people with hacks. We do not support illegal use of software.
3/29/2012 3:51:07 PM • Compaq iPAQ Home... • Answered on Mar 29, 2012
IPAQ Internet Appliance
You inquire on your nearest Internet Service Provider (ISP) for a DSL plan. DSL provides a bandwidth 3 to 4 times of the dial up.
10/7/2009 5:28:40 AM • Compaq iPAQ Home... • Answered on Oct 07, 2009
How do you reset the compaq I-A internet appliance
when u power up the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768 then aply and ok then resatrt then it issue is solved.
If u can not able to see that menu then u need recovery disk.
6/5/2009 3:28:30 PM • Compaq iPAQ Home... • Answered on Jun 05, 2009
MSN companion support
Unfortunately, since HP purchased the Compaq brand, it is very difficult to find contact numbers for compaq, You may need to search the compaq / HP websites for contact numbers, and ask to be transfered to one of thier representitives.
5/30/2009 6:21:57 AM • Compaq iPAQ Home... • Answered on May 30, 2009
Compaq was bought with msn companion service required
This is where you should be in contact with Comcast Tech Support 1-888 262-6300.
The INSTALL tech should have had you on-line before he left.
You need to conect your TV/Computer Cable to a Cable modem and a CAT 5 cable to your NIC (Network Interface Card)
All the lights on the modem should be on except the TEST light and the DATA light should be blinking.
You may have OLD drivers for the Cable modem, download those from another computer from the modem MFG.
Nothing else is required.
1/23/2009 6:34:33 PM • Compaq iPAQ Home... • Answered on Jan 23, 2009
2answers
My computer stays in dos
"ESC" or "Ctrl ESC"
1/19/2009 4:13:20 PM • Compaq iPAQ Home... • Answered on Jan 19, 2009
2answers
I brought a used campaq IA-1 and cant delete old users and add me
there is only one way to restore this system, you will have to take the hard drive out and hook it up into another desktop and install windows 98/me or 2k to it and then put the drive back into the compaq more than likely you will have to download drivers for it as well
1/16/2009 7:42:07 PM • Compaq iPAQ Home... • Answered on Jan 16, 2009
2answers
I need help with my compaq computer
Could be you tried to upgrade the current version you have why dont you repair the current version if you are using XP and the message will dissapear
11/15/2007 5:08:50 PM • Compaq iPAQ Home... • Answered on Nov 15, 2007
2answers
My compaq 610 windows logo is stuck during booting and even if I want to format it. Any help?
Windows 7 should be the OS. If you go to safe mode, it should complete booting and then you can list the errors but I suspect there is a driver error. Maybe the wrong version in there.
4/16/2024 12:12:58 AM • Compaq Computers... • Answered 4 hours ago
Wife forgot the Password on Compaq F700. How can we reboot and change password, F11 will not work.
From the Service manual https://www.manualslib.com/manual/71736/Hp-Compaq-Presario-F700.html?page=43#manual Unknown user password If the computer you are servicing has an unknown user password, follow these steps to clear the password: NOTE: These steps also clear CMOS. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the 1. computer on, and then shut it down through the operating system. Disconnect all external devices connected to the computer. 2. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and 3. then unplugging the AC adapter from the computer. Remove the battery (see Battery on page 37) 4. Remove the real-time clock (RTC) battery (see RTC battery on page 44) 5. Wait approximately 5 minutes. 6. Replace the RTC battery and reassemble the computer. 7. Connect AC power to the computer. Do not reinsert any batteries at this time. 8. Turn on the computer. 9. All passwords and all CMOS settings have been cleared. Videos as well https://www.google.com/search?q=Compaq+F700+reset+admin+password ..
3/19/2024 5:22:06 PM • Compaq Computers... • Answered on Mar 19, 2024
4answers
How to download whatsapp on laptop
As WhatsApp was originally designed for phones the process adn solution are not as straight forward as you might think, See the sites listed below: Download WhatsApp For Laptop PC Windows 8 1 8 7 Install Whatsapp http://fasttechbuzz.com/download-whatsapp-windows-8-1-7-pc-laptop-free/ download-whatsapp-for-windows-laptop-160x120.jpg If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
1/28/2024 5:02:48 AM • Compaq Computers... • Answered on Jan 28, 2024
Where can I find the latest BIOS and drivers for a Compaq Evo N610c laptop
It is 22 years old and there is not support for the virus magnet that is called Windows XP!
COMPAQ N610C QUICKSPECS Pdf Download ' ManualsLib
ManualsLib https://www.manualslib.com > manual > Compaq-N610c View and Download Compaq N610c quickspecs online. Compaq OWNERS MANUAL Notebook N610c. N610c laptop pdf manual download. Also for: Evo n610c. Drivers https://www.google.com/search?q=compaq+evo+n610c+laptop+drivers+download 'Latest' BIOS Upgrade is 2004 (2 year support) https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade+download https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade ..
1/27/2024 11:26:47 PM • Compaq Computers... • Answered on Jan 27, 2024
Hp compac nx6110 drivelock HDD BAY password, reset
Hey readersFollow these steps to troubleshoot that issue. Warning -Please don't your that tip for illegal work . Its only for personal and training purpose. You can also follow my tip
12/16/2023 6:38:16 AM • Compaq Computers... • Answered on Dec 16, 2023
Compaq evo n115 boot from usb
Is is probably too old to take Win 10. Also, USB support normally starts once Windows is loaded. During Boot up, it looking for a hard drive or Bootable CD Media. By default, the notebook can start only from a bootable hard drive or bootable drive medium in the notebook. https://www.google.com/search?q=Compaq+evo+n115+boot+from+usb It is 21 years old!!
QuickSpecs
NTS Computers Technology BV https://www.nts.nl > pdf > Compaq_EVO_N115 Compaq Evo Notebook N115. DA-11059. World Wide - Version 7 - August 12, 2002. 1. Overview. What's New. • AMD Athlon™ 4 and Duron™ processors with PowerNow ... 15 pages..
10/17/2023 3:43:03 AM • Compaq Computers... • Answered on Oct 17, 2023
Compaq presario desktop SR1000 wiring diagram
You can download upgrading and servicing guide from COMPAQ PRESARIO SR1000 - DESKTOP PC MANUAL Pdf Download ' ManualsLib
9/20/2023 5:18:41 PM • Compaq Computers... • Answered on Sep 20, 2023
Compaq iPAQ Home Internet Appliance IA-1 (178358-001) PC Desktop Logo
Popular Tags
13 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
ipaq internet appliance
  • Computers & Internet
