20 Most Recent Compaq Presario 7594 PC Desktop Questions & Answers
If the old hard drive is still working, then you could make an image of it and restore that image on the new hard drive removing the need to reinstall the Operating System.
There are several free programs available that can make the image:
Easeus Todo Backup
Paragon Backup & Recovery 2012 Free Edition
If the old drive has failed and you do not have a full backup, then you will need to reinstall the operating system and all your programs and data that was on the old drive.
Compaq Presario... | Answered on Jan 16, 2012
to download the drivers for your crystal eye web cam. Go to this link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=94524
When you get there, select where you see "Operating System", select your operating system (ex: XP, Vista, or Windows 7). It will then show all the drivers for your operating system...scroll down until you see the driver audio software and then download and reinstall it. Hopefully this will help...good luck.
Compaq Presario... | Answered on Aug 30, 2011
try to boot it by pressing F8 key while booting
then restore it back to earlier days
If you can't boot it to safe mode then you need to reinstall your windows using your quickrestore CD/DVD
Compaq Presario... | Answered on May 07, 2010
You should replace the unit with a new one. Most new software today requires at least 1Ghz processor, recommended 2 Ghz.
Also, this is not a software update. You must open the box and replace the CPU on the mainboard with another compatible one that uses the socket 370 FC-PGA.
Unless this unit is absolutely necessary for business like running machinery, it should be replaced outright as you can get better hardware for just a few hundred dollars.
Compaq Presario... | Answered on Mar 18, 2010
try eBay, they have some really good deals
Compaq Presario... | Answered on Sep 26, 2009
Please try to check from this URL: http://fileshare.eshop.bg/most_popular/list_400.html. regards
Compaq Presario... | Answered on May 10, 2009
what is the make and model of your pc because the one you listed is non-existent
Compaq Presario... | Answered on Feb 12, 2009
Reforamat you desk top computer using your windos operating system disk..thank you
Compaq Presario... | Answered on Nov 16, 2008
by working fine, I assume you mean the monitor goes into its test/diagnostic displays. If that is the case, most likely your roommate has hit upon more or less the correct deduction.
Two possibilites should be attempted before assuming to much more tho, one being the connector from the monitor to the computer, check for bent pins on the connector that goes into the computer. Do not worry about what appears to be a missing pin, that is normal for a SVGA connector, only look for bent pins. If you have one of those, it will have to straightened out CAREFULLY with a small metal tube as exists in some ball point pens or a small tweezer, but please be careful as they are very sensitive to over-pressure.
If a bent pin is not the cause then try reseating the video adapter card in the computer, meaning open the case ( with power off and computer unplugged ), take the screw out that holds the video card in place, pull out the video card and immediately place the card back into its slot on the motherboard. Do not try placing the card in another slot until you see if this works. put the adapter holding screw back into its former position and screw it back into place. Be careful that the adapter is properly seated in its slot, not doing so will result in NO VIDEO or even much worse conditions, such as a possible short on the motherboard, resulting in a fried motherboard. I don't think you want that. If this doesn't fix your situation then chances are as your roommate suggested the video adapter card may be bad, but there is one more possible suggestion that might just work, and that is if the video adapter is a PCI card, you may be able to place the video adapter into another PCI slot on the motherboard, above or below its present location. In a few cases that might help you ( assuming you are dealing with a PCI adapter as there is only one AGP slot on a motherboard. ). Never remove or replace components with power applied or even with the power plug still plugged into the wall socket. Newer motherboard built since 2000 will often still have some voltage applied to them from the power supply if the unit is still plugged into the wall socket.
Come back to me and let me know how it goes. Would appreciate it.
Compaq Presario... | Answered on Aug 28, 2008
sherylannie,
does your Compaq Presario SR1435IL have the original FreeDOS, or do you have another OS installed? If you still have the original FreeDOS, I would reccommend upgrading to at least Windows XP, depending how much memory you have in it. If you have the factory 256MB of memory, Windows XP should work, but if it's too sluggish, I'd personally reccomend at least 512 MB, but if you want Windows Vista, my personal opinion would be at least 1GB. Or, if you already have XP, click "Start", then click "Control Panel", then "Printers and Other Hardware", then, on the left, you should see "See Also" and click on the first line that should read, "Add Hardware". Click that and you should be able to follow it from there, just follow the prompts. It isn't all that difficult, if you just know where and what to click. Other than that, if nothing seems to help, maybe you can go to HP's web-site at: http://www.hp.com/support/chat, or you might have other options available at: http://www.hp.com/go/assistance. (The only reason I know what little I do, is because I own A Compaq Presario myself, lol. I hope I've been able to help, and if not, try those websites mentioned above.
Compaq Presario... | Answered on Jul 28, 2008
A kindred Soul! I have on old POS Presario myself that i keep bandaging.
You have robably overcome your issue by now.
Try F8 safe mode. Use CCLeaner to get rid of old stuff.
Compaq Presario... | Answered on Jul 17, 2008
The drivers on the HP site are for Windows 98, Me. Try the drivers off the ESS site. Find the appropriate Allegro driver for Windows XP (or try each of them). Good Luck.
Compaq Presario... | Answered on Jul 16, 2008
First make sure the hard drive is reconogized in the BIO's, then do a clean install of XP choosing to delete the existing partition and install into the undefined space. choose to format the drive NTFS. if it still fails after this, sounds like you will need to replace the hard drive. Also the CPU speed will need to be at least 700 mhz for XP to work correctly but a higher mhz is all ways better. BPCS
well, it probably doesn't recognise that you have an operating system (if you do) because of possibly a corrupted installation...try reinstalling windows on your harddrive, but it's recommended to format anything on your harddrive before you reinstall windows....if you need to backup what you have on your harddrive, you could buy a casing for it so that you can make it external.
Compaq Presario... | Answered on Jun 28, 2008
Hi, Take the 4 or 5 screws out of the back, then grab the top of the front of the case (the bit that ridges up) then pull that while PUSHING against the CD drive. The front and the casing comes FORWARD. These are the most awkard cases I have seen but once you get the gist of it it's easy. Give it a go then let me know. Dont be affraid to pull hard!!!!
Compaq Presario... | Answered on Apr 21, 2008
visit www.welcome.hp.com & search compaq desktop 7500 software driver.or go to drivercollection.com if try & download it
Compaq Presario... | Answered on Feb 18, 2008
Compaq Presario 7594 PC Desktop Logo
24 questions posted
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
need driver audio
  • Computers & Internet
