20 Most Recent
Dewalt D55153 1.1 HP Continuous 4 Gallon Electric Hand Carry Compressor Questions & Answers
My DeWalt D55153 oil-lubed compressor won't get up to pressure, and runs continually trying to.
The issue of low pressure that you experience is usually caused by air leaking from various fittings and or broken valves or valve plate gaskets. While the compressor is filling, spray soapy water on all fittings checking for leaks. If no leaks are found then suspect the head area of the pump. Usually when valves are bad , you will notice that air is blowing out of the intake port. With air filter removed and tank empty of air, start compressor and feel for good suction at intake, as the compressor reaches maximum pressure, air will begin to blow out of the intake and you will not feel suction. If this is the case, replace valves and or valve plate gaskets. ;good luck with ;your repair.
Air compressor not unloading
Check the pressure switch. The unloader valve is actually in the pressure switch where the small air line from the tank check valve attaches to it. When the pressure switch turns the motor off it then lets the head pressure bleed off so the motor can restart the next time pressure drops in the tank. If it's not working and bleeding off the head pressure the cold start valve (the one with the pin in it) also won't open so the motor can restart and warn up properly.
Dewalt D55168 225 PSI Air compressor: What are the preset pressure limits for this model? Is it actually 225 - 180?
https://www.manualslib.com/manual/494085/Dewalt-D55168.htmlSpecifncationsMODEL D55168WEIGHT 88 Ibs. (39.92 kg)HEIGHT 41.75" (1060.5mm)WIDTH 19.0" (4826 mm)LENGTH 21.25 (539.8 ram)AIRTANK CAPACITY (GALLONS) 15 Gallon (56.8 fiters)APPROX CUT-_N PRESSURE 160 PSI (1103.2 kPa)APPROX. CUT-OUT PRESSURE 200 PSI (1379.0 kPa)SCFM @ 90 PSI (620.5 kPa_ 5._cant get fixya comment to work so will edit here...The 200/160 are the typical DS55168 settings from factory and meet the 90 psi @ 5.4 cfm rating.Pressures can be adjusted to a MAXIMUM 225/185 with a resulting lower cfm rate.I'm not familiar with "type 9". Likely nothing special just different setting from factory?
