20 Most Recent
Carrier 5 Ton Complete Split System Heat Pump Or Gas Electric Questions & Answers
Suction pressure drops out
I hope that you are using DUAL MANIFOLD guages to check this. I am not sure what you mean by drops out.
My car is over heating
check your over-flow bottle & radiator for coolant ( this is the usual round silver cap in front of engine compartment // says DO NOT OPEN WHEN HOT !!!!!!!!! ) if empty ,look for leaks or have pressure tested for leak ------------ also check to see if electric radiator is turning on when it reaches operating temperature , this fan will also run or cycle on & off with the air conditioning on....--- if not check under hood fuse // relay for this circuit......
Compressor stopped working. Air
Check for power out of the contactor...is the condenser fan running?? If so then the compressor should have power...could be the compressor capacitor...or a bad compressor.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
