20 Most Recent
Compaq Inkjet IJ600 Printer Questions & Answers
My printer ij600 is not
that is because the ij600 will not normally work with anything newer than xp as the drivers were not developed beyond that system.
Printer grinds when trying to
Clean and very lightly lubricate the tracks and guides that the heads run on. Make sure that the belt and gears are clean and completely free of any oil or ink etc.
Where can i get a windows7 compatible printer
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
I am looking for the driver software to install on
HP bought Compaq a few years ago and apparently stopped supporting that printer after Win XP. There is no driver for vista. you may want to try the drivers for Win 2000 as Vista has similar code as Win 2000, and some of those drivers work in Vista. see:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=181&lc=en&cc=us&dlc=en&sw_lang=&product=217389
The cartridge tray doenst slide. Cannot remove the
Disconnect the power; remove the printer/USB cable.Apply litytle sewing machine oil on a piece of cloth and firmly apply on the steel rod. Please ensure just a little oil film is put on the rod. Now without connecting the printer with the computer just turn on the printer & then turn it off after 15-20 seconds. Repeat this 4-5 times. Now when you'll open the cover while keeping the printer on, the cartridge box will slide to center.
Do I need diffrent drivers for Windows 7?
Yes most assuredly. BUT there is NONE for Win 7, & doesn't look like there will be :( IT may work Run as Administrator, & in compatibility mode, set to XP SP2 , though, I guess that's all one can try?
