20 Most Recent
American Standard 3011001.02 Cadet 3 FloWise Round Front Universal Bowl with Bolt Caps - White Questions & Answers
Squeaky toilet
As the water in the tank reaches the full mark, the valve that shuts the water off begins to close. As it closes, less and less water is allowed to go past the valve. When the tank is at the full mark, the water is shut off completely. It's like letting air out of balloon. The smaller the opening, the louder the squeal. You may need to replace the float and valve set or some how lower the water pressure at the toilet.
12/29/2015 2:57:09 AM •
American...
Answered
on Dec 29, 2015
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
