20 Most Recent
Coleman Maxa 5000 Er Plus Generator Parts - Engine Mount Gen Cover Pm0525302.02 Questions & Answers
I HAVE A 4 HP
Coleman PowerMate CT4090410 Operator Parts Manual
This unit uses an loader valve to control pressure, it will unload compressor and idle engine back until the pressure falls below 95 psig and the speeds engine up and loads compressor until cutout pressure is reached. I've linked to manual and the unloader is
Coleman PowerMate CT4090410 Operator Parts Manual Page 18
The item number is 9 and part number is 070-0056.. This part is around $100-$110. Ive repaired this type part on air compressors used on mechanics service trucks ., Depending on your skill level and access to tools and parts, it might be better to purchase a new one.g take time ti read to read and understand manual. Good luck
Find author reed farrel coleman
SORRY BUT - You are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use..
Hi everybody i have a
parts are available from any motor repair /rewind shop
capacitors are only specific for capacitance and voltage and can be obtained from the same shops or from e-bay
the pressure switch only switches the motor on and lets run until the full pressure is reached
it then switches off but switches back on when the pressure drops around 10 psi
If it was doing that there will be nothing wrong with the switch
if all else fails and it is a belt driven compressor get a new motor
The brand on the motor is immaterial as long as it is 5 hp or bigger and has the same voltage rating requirement
