20 Most Recent
Compaq (176763001) 120-Watt Power Supply Questions & Answers
I can't get my Compaq
no PC model stated, at all... wow, 1984 to 2014 compaqs.
wow.
the PSU is bad if the jumper wire test fails
easy as eating apple pie, do that test. the voltages in the PC case are safe, 12vdc max. (no do not short out power rails.
NO the ATX spec is published in the wiki
the first compaq are 20 pin then later 24
so ill do 24 , just wild guessing what PC model you have.
why must we beg model PCs'
its like saying a Have a FORD car, what ford what engine, see?
jump 16 to 17 (17 is ground)
do not hot wire power OK (good) pin 8,
do not or blow up a good PSU.
never hot wire anything you do not understand
in this case the pin 16 has pull up resistor 5k, in all PSU made on earth. and you ground it (0v logic) to tune power on.
see the schematic in this page, do not blow up IC2.
or you will be sorry, I promise.
http://www.pcdied.com/power.html#Jumper
this works on all PSU made ATX spec. per wiki.
1/13/2018 1:02:47 PM •
Compaq...
Answered
on Jan 13, 2018
1. how to test compaq
if you want to check your hard drive for errors
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
6/9/2011 7:34:59 AM •
Compaq...
Answered
on Jun 09, 2011
When i start my computer
Your motherboard has a short circuit with your computer case. Just put motherboard of the case and on it
6/2/2011 5:03:48 PM •
Compaq...
Answered
on Jun 02, 2011
My psu not working at
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
5/2/2011 5:11:03 PM •
Compaq...
Answered
on May 02, 2011
Dead
Get a generic switchable power supply, just look for something like "universal laptop power supply" in the shop of your choice. Be sure to get one with appropriate connector and voltage, at least 120 wats (as that is how much power your laptop will draw, a weaker supply can survive for some time but will fail eventually).
2/23/2011 12:19:57 AM •
Compaq...
Answered
on Feb 23, 2011
Where can i buy ps2018
I have compaq power supply "PS2018", Part no 288468-001, and is not working, of course.
The problem is that it will not "ignite", it just starts and stops 0,2 sec later... Where can i look for the cause,
2/18/2011 6:31:01 PM •
Compaq...
Answered
on Feb 18, 2011
I need to help me
hi... hope this can help....it's the most common for any power supply...RED is for +5V DC, BLACK is for Ground, yellow is for +12V DC...GREEN is for earth ground...in cases for a 12V output adaptor redi is the 12V and black for ground..pls. don't forget to rate and vote ...thanks......
2/16/2011 7:08:37 AM •
Compaq...
Answered
on Feb 16, 2011
9pin power smps burn
hi pyo,
replace it..troubleshoot it is good..but new one is better..
mastergani
2/9/2011 8:59:47 AM •
Compaq...
Answered
on Feb 09, 2011
How to repair power supply? it's not work. how to
I recommend you do not try to repair the switch mode power supply, Mains voltage equipment are dangerous if you do not know what you are doing.
Switch mode power supplies are not expensive to purchase, I suggest you purchase a new ATX switch mode power supply. There may not be many 120 watt available, but higher wattage power supply are more common, the mounting holes are standard.units
11/20/2010 3:44:14 AM •
Compaq...
Answered
on Nov 20, 2010
Compaq PS-7171-c1f1 model
There is, but I would NOT recommmend an untrained user to do it as it can be dangerous.
If you want to know you can unplug the PSU from the PC and short out a specific connector pin (green) with a paper clip, this causes the PSU to turn on and the fans spin.
If that works it usually means the PSU is OK.
But I repeat I would suggest NOT doing this unless you really know what you are doing and take the proper precautions as shorting the wrong pins can be very dangerous.
The best way is to borrow a spare PSU and try it or buy a cheap generic one just to try that out.
5/25/2010 8:28:48 AM •
Compaq...
Answered
on May 25, 2010
This type smps burning
CAN U SEND ME THE PICTURE OF INSIDE VIEW OF SMPS
THIS IS ONLY SOLUTION
ID IS ERKAMALSINGH YAHOO.COM
I WILL HELP YOU ONLY ON THIS WEBSITE
1/28/2010 12:54:13 PM •
Compaq...
Answered
on Jan 28, 2010
Hard drive not found in bios.
Thanks for using FixYa!
There are three possibilities why your HDD(hard drive) is not showing up. 1. Its already a bad drive (failing HDD mainboard). 2. Loose HDD cable inside your laptop. 3. Bad laptop sata port. Hopefully its just #2 but most of the time its #1. Bring your computer to a technician. They will be able to easily isolate the problem. I hope this helps.
Have a nice day
- HotRatchet
8/19/2009 10:32:56 PM •
Compaq...
Answered
on Aug 19, 2009
Power supply problem
i have a compaq computer power supply its not given the constant volts plz help
7/30/2008 12:36:22 PM •
Compaq...
Answered
on Jul 30, 2008
450 power supply
The cd may be bad, or if the power supply is just marginal, it may be failing when the cd motor spins up.
6/8/2008 3:42:13 PM •
Compaq...
Answered
on Jun 08, 2008
