20 Most Recent Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard Questions & Answers
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion.. 1. Remove battery + disconnect power 2. Hold down power button for 20 seconds 3. connect power only (no battery) 4. Turn computer on. If the beeps stopped.. get a new battery, if the beeps continue.. ABANDON SHIP!
11/21/2014 9:00:25 AM • Compaq Presario... • Answered on Nov 21, 2014
Computere slowed down after install service pack 3
delete temp files start>run>type %temp% and press enter delete all the files.
1/26/2014 1:10:39 PM • Compaq Presario... • Answered on Jan 26, 2014
Hello sir, my name is
you will find all drivers and software at HP support for all compaq laptops please follow link
http://welcome.hp.com/country/uk/en/support.html
2/18/2011 1:45:50 AM • Compaq Presario... • Answered on Feb 18, 2011
No boot no display
Probably a problem with the alimentation
12/18/2010 11:32:42 AM • Compaq Presario... • Answered on Dec 18, 2010
Do you have compaq designe cq40 311 br
Here are some that are available on e-bay...click the link below
http://shop.ebay.com/i.html?_nkw=compaq+presario+cq40+motherboard&_sacat=0&_odkw=compaq+presario+cq40&_osacat=0&_trksid=p3286.c0.m270.l1313
There are quite a few available for purchase...good luck.
9/17/2010 6:42:42 PM • Compaq Presario... • Answered on Sep 17, 2010
I TAKE COMPAQ PC BEFORE
Hello Sir,
I have sent you the link for your request, try downloading and installing the drivers.
Link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=435655&
8/16/2010 4:21:47 PM • Compaq Presario... • Answered on Aug 16, 2010
My screen is very dim and practically unusable.
aoto matik restart plese give me solution
4/4/2010 7:45:52 PM • Compaq Presario... • Answered on Apr 04, 2010
Which graphic cards will suit compaq presario
one of these
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201069609639&bop=And&ActiveSearchResult=True&Order=PRICED
3/19/2010 8:05:52 AM • Compaq Presario... • Answered on Mar 19, 2010
Picture will not fill entire screen, what do I do?
Try to adjust youre size with monitor? Should be a menu or adjust button on your monitor. Then you can extend vertical and horizontal sike. Good Luck
11/22/2009 1:35:13 AM • Compaq Presario... • Answered on Nov 22, 2009
2answers
I need to know how to access the hard drive on my
Good day jar
Well firstly, i wanna know if your trying to install windows? if so then a normal windows disc is not gonna help you, there is a option in you bois which you have to unset possible it is called visualize or sumthing,
then get a Dell or acer pre intaller oem windows disc, cos there is a lock on the hard drive which you cant remove with a normal windows os disc, or yust in stall vista
sure it will help
email me if you have any other problems
[email protected]
thanx bertus
11/4/2009 9:24:21 AM • Compaq Presario... • Answered on Nov 04, 2009
Compaq B1200 motherboard
go to nehru place IT HUB
9/25/2009 12:21:50 PM • Compaq Presario... • Answered on Sep 25, 2009
I have a pc compaq sg3113il having windows xp as operating system
So, where is the problem?
9/20/2009 12:53:22 PM • Compaq Presario... • Answered on Sep 20, 2009
Drivers for COMPAQ PRESARIO 3620 AMD
you might be able to obtain these at the HP website since they now own Compaq.
9/14/2009 11:11:14 PM • Compaq Presario... • Answered on Sep 14, 2009
Problem with System booting Compaq Presario 12XL500
Check your memory sticks to make sure that they are full inserted and did not come loose. Check the power from power supply going to HD. Make sure it is getting power. You can also remove your motherboard and test components with an ohmmeter to see if there are any burned out components which is very possible. Have seen bad boards and bad power supply's both cause your problem
9/9/2009 2:59:55 PM • Compaq Presario... • Answered on Sep 09, 2009
Missing compaq SG3113IL desktop PC motherboard cd
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodSeriesId=3549370&prodTypeId=12454
Select your model from this link then select your operating system and downlaod drivers .
Let me know if you need more assistanse.
Thanks.
9/7/2009 10:14:44 AM • Compaq Presario... • Answered on Sep 07, 2009
4answers
Compaq presario v3122tu laptop motherboard cd not getting anywhere
hi, Post the laptop model no and make so I can send you all the detail. you can download and install it. change the harddisk with greater space there shouldn't be any challenge on it. But you can't upgraid your cpu with duo core cpu. anyway you post the detail of you model, I'll post the detail answer. Thanks Arun
8/25/2009 6:17:04 AM • Compaq Presario... • Answered on Aug 25, 2009
Compaq laptop
seems ur windows have crashed. reinstall ur o/s
8/19/2009 5:48:59 PM • Compaq Presario... • Answered on Aug 19, 2009
Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard Logo
54 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
  • Computers & Internet
