1.) If your display is no disk it's possible
that your disk you inserted is corrupted or dusty, try to clean your disk with wet
clean cotton.
2.) If does not work it is also possible that
the CD is only a pirated, try to insert original CD and play it.
3.) If does not work again, try to remove the
cover of your DVD and checked all the connections of the DVD connector from the
circuit board, try to reconnect the connector and tightening it.
4.) Common problem from the DVD player is the sensor
from the DVD reader checked if it is dusty or not, tries also to clean it with clean
cotton.
5.) And if you try all of these method and
your DVD still doesn't play again, it possible that the sensor from the DVD
reader is defective try to replace the sensor with the help of technician.
61 questions posted
16 Questions
4 Questions
1 Questions
1 Questions
3 Questions
