20 Most Recent Powermatic 1792010k 2000 Tablesaw Questions & Answers
If your blade is square to the saw table, why would the accu-fence still be off?
Have you squared the fence to the blade/table. If the table is true to the blade, your mitre slot should also be. You can then squre your fence to the slot
8/18/2014 8:16:56 PM • Powermatic... • Answered on Aug 18, 2014
2answers
if its cutting in the angle. maybe the teeth on your blade are dull on one side and the blade is pulling material to the side. maybe the fence is ok.
8/3/2014 3:17:45 PM • Powermatic... • Answered on Aug 03, 2014
Can u buy Australian cord for powermatic 4
Yes. Buy any with a suitable connector and fit the plug for your country. Make sure the voltage is correct first!
11/1/2023 7:52:54 AM • Powermatic Saws • Answered on Nov 01, 2023
Phone number for powermatic 2+ parts
Hi Marsha- Here is the Powermatic website for customer support. http://www.powermatic.com/us/en/service-and-support/customer-support/ Hope this helps.
10/27/2019 11:51:04 AM • Powermatic Saws • Answered on Oct 27, 2019
What belt(brand/numbers)to replace the one on a Powermatic Artisan 63A Table Saw?
Probably a long out of date question but my suggestion is to purchase a link style belt to replace the old hard drive belt that comes with the saw. It'll deliver more power to the blade, run quieter and work better. I also recommend replacing the drive pulleys while you're at it. Get a couple of balance ones. You can get a link belt at Rockler or other woodworking outlets. http://www.rockler.com/1-2-power-twist-plus-link-v-belt
1/29/2016 4:09:50 PM • Powermatic Saws • Answered on Jan 29, 2016
Were can I buy parts for my Powermatic 2
we usually get our parts off of this site. http://www.ereplacementparts.com/ They have most of the things that we need.
7/8/2015 12:52:34 PM • Powermatic Saws • Answered on Jul 08, 2015
Powermatic66 single phase 3hp starter switch not working how do I as they say retrofit this switch
it is not the switch. it is the start run capacitor. it is located under the hump on the motor. becarfull when you uncover it, it may still hold a charge. after you have removed the cover you must replace that shiny things that has all the wires in it. careful to put the wires back that way thy came. and get a capacitor with the same UF Microfarits.
4/20/2015 2:45:12 PM • Powermatic Saws • Answered on Apr 20, 2015
Powermatic manuals
L Luke, closest I could find is May 1983. http://vintagemachinery.org/pubs/655/6140.pdf
9/4/2014 2:15:39 PM • Powermatic Saws • Answered on Sep 04, 2014
Accu-fence. After going beyond 12 inches on accu-fence, the measurement differs 1/16 of an inch to the end of table.. The saw blade is accurate to the miter slots within .002. DO not understand what i
Here is a link to the Accu-fence manual. It Includes the adjustments. From you description I think you will find that the adjustments will solve your problem http://content.powermatic.com/assets/manuals/2195075Z_man_EN.pdf
8/4/2014 2:07:06 PM • Powermatic Saws • Answered on Aug 04, 2014
How do I adjust the worm gear on my table saw?
I believe that that model of Powermatic has a lock for the blade angle that also extends and retracts the casters for moving the saw. You may have unlock or change the handle position to allow for blade angle adjustment. You can get a manual or information at the Powermatic website to show you how to change the settings on the saw. Hope that helps.
5/28/2014 7:33:30 AM • Powermatic Saws • Answered on May 28, 2014
Need help wiring a 5HP 1Phase motor on Powermatic 66
As you only have 4 wires from the motor it should be straight forward as two would be from the start winding (Black and red) and the other the run winding (White with yellow stripe and Blue). You should be able to check this with a tester as there should only be continuity between the wires as mentioned above. Reference the thermal switch, I am not 100% sure on the color codes but have attached a diagram which should help but will advise as best as I can on the connection. The diagram is for a high/low voltage but you can disregard the winding on 3 and 4 but should help on the understanding. Join the blue and black wire from the motor together and connect to the black wire from the supply. You should be able to run the motor (Excluding the thermal switch) by connecting the White with yellow stripe and the red wire together along with the white from the supply. To include this switch I would presume that you would connect the red wire from the motor to the brown wire from the thermal switch, the yellow wire from thermal switch to the White with yellow stripe from the motor and finally the white wire from the thermal switch to the white from the supply. 7d21c20a-e074-4f6c-b29a-d36df4a53146.jpg
1/30/2014 6:10:24 AM • Powermatic Saws • Answered on Jan 30, 2014
Powermatic 1792010k 2000 Tablesaw Logo
3 questions posted
Top Powermatic Saws Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Marty Warge
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
View Most Popular
Powermatic Saws
  • Powermatic Saws
Most Popular Question
blade square saw table accu fence still
  • Saws
