20 Most Recent
Omron Hem-prt1-z Thermal Printer For Hem-705cp & 8 Rolls Of Paper Questions & Answers
I replaced the batteries of my Omron Karada Scale BF511 and it's been showing Err. When I step on it, the scale reads up to a 110kg (and I weigh 76kg) before reading Error. Please help.
Here are some steps you can take to troubleshoot and potentially resolve the issue:
1. Make sure the scale is on a flat, stable surface: Uneven or unstable surfaces can affect the accuracy of the readings. Place the scale on a hard, level floor and ensure it is not wobbling.
2. Check the battery installation: Double-check that the new batteries are inserted correctly, following the polarity markings inside the battery compartment. Ensure there is good contact between the batteries and the terminals.
3. Calibrate the scale: Some digital scales require calibration after battery replacement or when experiencing issues. Check the user manual for instructions on how to calibrate your specific model. Calibration usually involves placing a known weight on the scale and adjusting it accordingly.
4. Clean the scale: Dirt, dust, or debris on the scale's surface or sensors can interfere with accurate readings. Use a soft, slightly damp cloth to clean the scale, ensuring it is dry before use.
5. Try weighing yourself multiple times: Step on and off the scale a few times to see if the error persists. This can help determine if the issue is consistent or intermittent.
How do I calibrate the omron hbf 516
I have one purchased at Costco in Mexico. The online company manual FOR THIS EXACT MODEL (HBF-514C) says you can choose metric or imperial. HOWEVER, that line in the manual that came with mine IS NOT IN MY MANUAL! That line and only that line was deleted from my manual, although the scale carries the exact same model number.
