20 Most Recent
Compaq iPAQ H3830 Questions & Answers
When i conect my iPAQ
Hi.there might be a damaged on your usb itself or usb port because it will not be recognized and read by the driver.
I have a telefunken tv
with most devices id just try the default password of 0000
or just put in as many 0's it will let you or try 1234 or type up as many times it will let u, so if u can enter 6 #s then enter "123456"
good luck.
those are the codes you should try to unlock it,
(they are default codes so if it was ever changed int he past it wont work)
Online with a Compaq iPAQ H3835 Pocket PC
The 3835 did not have WiFi capability so you can't get online. Probably not worth messing with unless you're a real techie. I think there is a distro of Linux that can run on it if you want to play with that.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
