20 Most Recent
Compaq Wireless Keyboard/Mouse p5304 Questions & Answers
I took my computer in
This wireless keyboard is super old (a relic )I'd say 17 years old, XP year 2001 oldand HP ended support on it years ago.we dont even seen them sold used now on ebay.if new batteries do not fix it nor the reset (pairing) button fails.and worse if your UNSTATED OS shows in device manager its is dead, then it is dead forever.if you are web connected, are you and PnP fails to find the driver, you are doomed.HP does not have. it. now.they did make unified driver for all 100s of models they made but I can not find it, at all now. did last year but not now.google this (no manuals found either)HP p5304see what you see, nada.it's dead.buy a wired mouseor new wireless.same answer for keyboard side.same.also (this is the radio module large version wireless keyboard relics)HPThe HP models 5187 or 5219crf/urf are 18 years old.(no w10 support)
When I replace the batteries in my mouse # 26751,
You have to reconnect the device. There should be a button on the bottom of the mouse and onthe reciever, follow the mfr's instructions but usually hold them down for 5 secs re-syncs them
Don't forget to rate the advise!
http:www.aa1consulting.com
I have a Compaq wireless
Hello, yes you should have 3 items; mouse, kbd and the receiver which plugs into the computer.
Regards,
nicam49
I have a compaq keyboard
YOU DON'T NEED TO INSTALL IT IF YOU ARE USING WINDOWS XP,VIESTA,WIN 7,ETC.
JUST PLUG THE USB SENSOR AND ON THE SWITCH AT THE BACK OF THE MOUSE AND START USING THEM.
Mouse lights up but won't
have you run the pairing procedure? Usually there's a button on each device... press and hold it on the receiver unit, then press the appropriate button on the keyboard and mouse.
Make sure you've got fresh batteries in each.
The red light on my
The red light is the laser that senses where the mouse is moving. In this case it's a hardware failure, the bulb/laser died out.
The clicker is a separate part to the device so it will still work, and it should still connect to your computer like you stated.
If you are really attached to the mouse, you might be able to find a general computer store/ technician who can replace the laser but it'd be costly.
Your best bet is to either see if the company will replace it, or you might have to scrap the mouse for a new one.
Best of luck! Your mouse is important so I hope it works out well :)
How do i install a wireless mouse
Kathy,
There are two items that you have. A wireless mouse and a sensor for it. The sensor is attached to the PC while the mouse stays with you. And of course you must have received a CD with the drivers in it.
Insert the CD in the drive and let auto read and install the drivers. Once done, then insert the sensor and allow the Windows to detect and load the drivers. After that happens then only you would be able to use your mouse.
Please follow these steps.
Keybord buttons on top dont work
For those keys to function, you need to install the drivers and software that came with the keyboard. If you don't have the disk, you can find the software and drivers for download at the keyboard manufacturer's website.
Optical mouse
Yes you may use your regular keyboard if it plugs into the keyboard port the the wireless mouse plug into a usb port.
Depending on how the wireless mouse/keyboard reciever plugs into your computer. it's either it splits into one keyboard plug and one mouse plug OR just on usb plug.
Some one gave me a older wireless keboard
hello there when you plugged it in did u get a new hardware found that poped up on the taskbar? if so was it able to fully install the device or did it tell u that it could not install the device with out the cd rom you can use the web to download the drivers for it if you don't have the cd rom ok please let me know how this goes best regards mike
Wireless keyborad
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
Wireless mutimedia keyboard
Yes, there should be a receiver for the wireless keyboard. If you don't have one, it would be more cost effective to purchase a new one as they can be had for under $20.
Thanks and please take a moment to rate as fixya.
