20 Most Recent Generac Generator 5989 2,700 PSI 2.3 GPM Gas Pressure Washer Questions & Answers
2answers
No sight glass on my Generac Pressure washer nothing to tell me how much oil to use
TAKE YOUR PINKY FINGER AND TAKE AND PLACE IT IN THE OIL FILL YOU BE ABLE TO TOUCH HE OIL THERE IS ALSO A SLIT INSIDE THE OIL FILL INSIDE OF OIL FILL .FILL THE OIL FILL TO THE POINT THAT THA IT COVERS THE TOP THE SLIT BUT DONT OVER FILL THE MOTOR THE OIL SHOULD JUST COVER THE SLIT I HOPE THAT THIS WILL HELP YOU
5/22/2014 3:05:55 AM • Generac... • Answered on May 22, 2014
Oil
Contact company, they should be able to answer this. Rule of thumb 10-30 is a good all around oil. If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
4/13/2014 7:44:26 PM • Generac... • Answered on Apr 13, 2014
I can not find how much oil to use in the Generac Pressure washer 2700.
the only thing i can suggest put your pressure washer on level surface and start fill the oil when gets to the right level the oil start coming out
4/21/2013 7:18:23 AM • Generac... • Answered on Apr 21, 2013
How much oil do you put in the pump for a generac pressure washer model # 01676?
Check and see if there is a sight glass on the side of the pump. If there is, just fill it until the oil shows up about half way in the sight glass.
9/23/2012 12:43:03 AM • Generac... • Answered on Sep 23, 2012
Where can I get fuel pump for Generac generator model 09856-0 5000watt
Generac should be able to advise; https://generac.ordertree.com/
2/3/2024 7:04:38 AM • Generac... • Answered on Feb 03, 2024
Generac 389cc Generator. How to set the timing on the generator please?
Question edited for clarity, spelling (timeing) and toss in some CAPS. Engine timing and Valve timing in the link. https://www.google.com/search?q=Generac+389cc+Generator.+How+to+set+timing You could also search for a Service Manual, but you will need the model number rather than the cubic capacity of the engine cylinder. ..
1/13/2024 2:42:07 AM • Generac... • Answered on Jan 13, 2024
Generac Standby Generator. I have a red blinking light on on the OFF button on the Guardian 2.0 control panel?
Question edited for a lot more clarity. Model and KVA helps. Question moved from Televisions to Generac Guardian category. Information to troubleshoot in the link and video. https://www.google.com/search?q=generac+guardian+standby+generator+switch+off+led+flashing+red ..
9/22/2023 4:10:31 PM • Generac... • Answered on Sep 22, 2023
Generac won't turn off unless I pull the fuse.
James, Which unit are you dealing with 12k 15k 17k 20k 22k 24k? You have a ats. automatic transfer switch?
6/27/2023 12:25:22 AM • Generac... • Answered on Jun 27, 2023
Generac 0058711, 10KW Generator. How to reflash home standby 10kW Generac generator model number 0058711 please.
That is a full home back-up unit. You need dealer support. Contact them direct. There is nothing online about re-flashing.
Support For Your 0058711
Generac Power Systems https://www.generac.com > product-support-details File Type Manual (PDF) Item Number Langu... Emissions Warranty Statement WARRANTY STATEMENT EMSN E P3 0J3335 EN Exploded View (Control Panel) EV CONTROL PANEL ? HSB 0J3707 EN Exploded View (Enclosure) EV ENCLOSURE HSB 2011 0J4730 EN View 29 more rows
6/11/2023 3:58:22 PM • Generac... • Answered on Jun 11, 2023
Generac 7kw 05837 RPM Sensor Loss But Otherwise Operates Totally Fine
Replace battery with new proper sized.
Group 26R
12 Volt
525 CCA Minimum
5/13/2023 8:34:30 PM • Generac... • Answered on May 13, 2023
I have a Generac ix800 that starts but produces no power and I don't see the overload light on. Is it the inverter panel?
need a meter to diagnose and test circuit and wiring ---check breakers also
3/28/2023 4:50:15 PM • Generac... • Answered on Mar 28, 2023
2answers
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
1/11/2023 2:04:47 AM • Generac... • Answered on Jan 11, 2023
Tool Shed SG6500E Generator. What kind of gas cap goes on it please?
Question edited for clarity, full 'make model (what it is)' Question moved from Cars and Trucks. $262 for a new tank and cap! https://generatorguru.com/6500e-6500w/ One of these looks similar https://www.google.com/search?q=tool+shed+sg6500e+generator%2C+gas+tank+cap ..
12/21/2022 6:39:06 PM • Generac... • Answered on Dec 21, 2022
3answers
My generac generator wont start,making a clicking noise and battery is fully charged
Have somone hold the start button while you measure the voltage across the battery. If it is less than 11 volts, then the battery is bad.
10/22/2022 9:30:33 PM • Generac... • Answered on Oct 22, 2022
Generac 16kw generator starts on its own in automatic mode
Check the wiring from the utility through to the autostart control.; make sure all connections are solid and the wire itself is in good condition. New wire is no guarantee, several times I've had wire with a break somewhere in the reel. A non-contact voltage detector may helpful; start at the controller end, go to the other end of the wire, and see where you lose the voltage detect. It will detect voltage up to the break if you can keep the detector close enough to the wire.
7/31/2022 10:59:51 PM • Generac... • Answered on Jul 31, 2022
Generac Generator 5989 2,700 PSI 2.3 GPM Gas Pressure Washer Logo
Popular Tags
11 questions posted
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Generac Electrical Supplies
Most Popular Question
many liquid gallons in 1 000 cfh natural
  • Electrical Supplies
