20 Most Recent Generac 6051 Guardian Series Air-Cooled 10kW 120/240V Single Phase Steel Residential Generator with Nexus Smart Switch Questions & Answers
The brushes on Generac automatic units are most likely not lined up with the slip rings and will wear down and burn out very fast. There is no way of checking this during assenbly because they are hidden from view and the generator has to be dismantled to be able to replace them. It's an extremely poor design and Genrac should face a class action lawsuit for producing this piece of junk.
Generac 6051... | Answered on Apr 23, 2013
If it is new, you should contact the seller and/or manufacturer for warranty - before you attempt to service yourself. Follow their instructions to troubleshoot / diagnose
Generac... | Answered Yesterday
Please ask your supplier, they can answer your question.
But if you need more support or learn more about diesel generator set, maybe you can visit website: www.dieselgeneratortech.com, or contact sales@dieselgeneratortech.com for inquiry
Generac... | Answered 3 days ago
Model not found on Generac web site using model number or serial number.
Generac contact information on their web site to request assistance:
https://www.generac.com/service-support/contact-us/online-form
Generac... | Answered on Oct 14, 2019
High qality diesel generator set website: www.dieselgeneratortech.com
Generac... | Answered on Oct 11, 2019
Diesel generator set faults solutions: www.dieselgeneratortech.com
Generac... | Answered on Sep 24, 2019
It is common to cut off the fuel supply by stopping the diesel engine to shut off the transmission of fuel or air. The method is to install the solenoid valve on the pipeline of oil or gas supply, and control the opening and closing of the solenoid valve by pressing the electric button. So the solenoid valve is out of control. It can't cut off the fuel and air.
More technology supports, suggest you to contact the Starlight manufacturer( diesel generator set), they supply Cummins, Volvo, Perkins generator and provide services supports, the email address: sherly@dieselgeneratortech.com.
Generac... | Answered on Sep 21, 2019
If you are interested in diesel generator, please contact sherly@dieselgeneratortech.com
We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Generac... | Answered on Sep 19, 2019
have one my self. i am an electrican in canada. can walk u threw all your questions. easy to maintain. da0875@gmail.com
Generac... | Answered on Sep 04, 2019
What is the alarm display? And what is your generator brand? If possible to say detail it will be better.
Here is diesel generator website:
https://starlightgenerator.en.made-in-china.com/
Generac... | Answered on Aug 23, 2019
Most of the time it is the AVR that has blown. Check out our videos on how to test them.
We hold your AVR in stock and have a whole Help Center dedicated to helping people fix their Portable Generators. Check it out on our site. https://www.generatorguru.com/
Generac... | Answered on Aug 19, 2019
5w30 syn or straight 30w about a quart and then check the stick
Generac... | Answered on Jul 12, 2019
Beware of an adjustment complexity with an new kind of poweroutlet automatic voltage regulator avr , have you measured the generator UNLOADED for 230 volts ?
because it can be normal that 67 volts output changed when you connect an paint heat gun i was surprised a few weeks ago that i get an GENMAC 8000 that is a look a like generator coming from china build . first i was measuring some of the same output AC instead of 230volts.
Generac... | Answered on Jun 28, 2019
I believe you mean the fuel pump. They do fail and leak, so likely you need a replacement. Make note of where the 3 lines connect (inlet, outlet, impulse air) Also check for fuel in the crankcase (oil) and drain and replace if necessary.
Generac... | Answered on Jun 13, 2019
Generac 6051 Guardian Series Air-Cooled 10kW 120/240V Single Phase Steel Residential Generator with Nexus Smart Switch Logo
Popular Tags
7 questions posted
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Generac Electrical Supplies
Most Popular Question
under voltage alarm shutdown generac 10
  • Electrical Supplies
