20 Most Recent Kipor 3000 Watt Generator Questions & Answers
It helps that you said it was " in storage".
I am assuming the unit runs on gasoline.
If so, it is probable the gasoline has turned to gummy deposit and the carburetor must be rebuilt.
This is common with any gasoline engine that sits for a long period of time.
I have this problem with my 2 generators.
In the future, if this was the problem, the gasoline must be drained out at the very start of the "storage" time.
God bless your efforts.
Kipor 3000 Watt... | Answered on Jul 15, 2016
Here is a PDF with troubleshooting tips and wiring diagrams: http://www.kiporpowersystems.com/pdf/service/IG3000~1.PDF
From Page 36 - If no AC power, first check for continuity between the terminals on the receptacle and the red and black wires going to the inverter module. See the wiring diagram. Check the contacts for discoloration or evidence of burning.
Kipor 3000 Watt... | Answered on Jun 21, 2014
Possible dirty contact or defective.
Problem is mixture, either a carb jet or adjsutment. Closing the choke is making the mixture rich and allowing to run, so when open it is too lean due to blocked jet, or incorrect adjustment
Kipor 3000 Watt... | Answered on Nov 16, 2013
I would try disconnecting the oil pressure sensor temporarily to isolate that circuit as the possible cause of it shutting down.
Kipor Electrical... | Answered on Apr 15, 2019
Give you some suggestion, hope can be helpful for you.
Here is some basic principles for troubleshooting generator faults:
1. Check outside of generator firstly then inside
In the case of generator failure, the possible fault locations outside the electronic control system should be checked firstly. This can avoid a fault that is not related to the electronic control system, but make complex, time-consuming and laborious checking on the sensors, computers, actuators and circuits of the system. The real fault may be easier to find but can not be found.
2. Code priority
Electronic control system generally has fault self-diagnosis function. When some fault occurs in the electronic control system, the fault self-diagnosis system will immediately monitor the fault, and alarm or prompt the operator through warning lights such as "monitoring engine". At the same time, the fault information is stored in code. For some faults, the fault code should be read according to the method provided by the manufacturer before the fault self-diagnosis system is checked, and the fault location indicated by the code should be checked and eliminated. After the failure code refers to the elimination of the fault, if the engine failure phenomenon has not been eliminated, or no fault code output is started, then the possible fault location of the engine is checked.
dsc01081_??-gchmaamodmqy1czm0regslps-1-2.jpg https://www.dieselgeneratortech.com/generator
Kipor Electrical... | Answered on Apr 12, 2019
check the instruction book on your generator - for the exact steps to follow after this icon appears.
Kipor Electrical... | Answered on Feb 10, 2019
screenshot_2019-01-25-14-07-29-5m4vg20v4mjgdjzqxftqb5de-2-0.png Qu'est ce qui provoque cet insident
Kipor Electrical... | Answered on Jan 25, 2019
If you are in Europe, you run 240 VAC @ 50 Hz. If you are in the U.S., you run 120 or 240 VAC both @ 60 Hz. Assuming that it's NOT an inverter generator, if your engine is running too fast or too slow, your frequency will be too high or too low which can damage sensitive electronics or electric induction motors. Apparently, you have a well controlled / monitored generator. While it is still running during those 20 seconds, I would check for your local voltage at it's output. If it is well above or below it's rated voltage, it's frequency will be out of range also, again, assuming that it's NOT an inverter generator. If it is an inverter type, you'll have to take it to a service center for adjustment. If not and the voltage is out of range, I would try adjusting the engine speed to bring it back into spec. I am in the U.S. My father in law had a craftsman 3,650 watt generator that didn't have the monitoring that yours does but it did the same thing. It would run for 20 or 30 seconds and quit. The oil was up and all looked well. I disconnected the low oil pressure switch and it ran fine. I replaced the switch the next day. I have a 7,000 watt Troy Bilt that I have wired into my house for emergencies but I bought a small, cheap Champion brand 1,400 watt generator for portable use. I brought it home and fired it up and out of the box it was putting out 133 VAC instead of the standard 120. I turned the idle down until it read 120 VAC and it works fine as long as I don't try to run a window A/C unit or fridge. It doesn't have the guts to start the compressor but it works great for lighting, TV's or small hand tools. Good luck.
Kipor Electrical... | Answered on Jan 03, 2019
press and hold the function button turn on the ignition and hold until it ges into test mode should display something like ph 2 then start it up and test the output voltage and wether or not it produces power correctly. if it does test the output voltage with a multimeter to confirm the output is the same as displayed on the machine if not remove the control panel and adjust the trim pot on the rear of the display panel until it displays correctly,
if not it could be the carbon brushes in the altenator or the avr which is a black box bolted to the frame
Kipor Electrical... | Answered on Oct 25, 2018
1. Check the voltage of battery whether is 12V or 24V; 2. The voltage of battery is low when the generator is still, then it is necessary to dismantle the battery and charge the battery with charger.
3. If the voltage of battery is low but the generator is running, it indicates that the diesel engine driven charger doesn't work; then it is necessary to stop the engine to check the fan belt.
4. if the fan belt is not loose, please check the charging AC diesel engine driven charger, please refer to Manual for Diesel Engine.
5. If the battery can not store the electricity, please replace the battery for a new one. https://www.dieselgeneratortech.com/generator-sets/discovery-and-elimination-of-faults-of-the-control-system.html
Kipor Electrical... | Answered on Sep 30, 2018
Kipor 3000 Watt Generator Logo
12 questions posted
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kipor Electrical Supplies
Most Popular Question
kipor 3000 generator cannot get started
  • Electrical Supplies
