20 Most Recent
Compaq Presario Modem/NIC Combo (212786001) Questions & Answers
Modem name is Data Fax Softmodem with SmartCP
we have no idea at all what you are running there at all
NO PC stated
NO OS stated (xp,vista/w7/8/10, why?)
An AT%T what? what modem exactly so they did not set it up for you ? no way they would not do that after all its' their modem and you run it from them as a service.
does your unstated PC use Ethernet cable Cat5/6 to the At&T modem or router? that is the fast way to get internet
fastest, most easy, and just plugs in.
your post lacks all key facts,
sorry.
Setting up home network one computer has ethernet
The following should fix your problem. This one is available at Radio Shack. You can typically get them at most electronic retailers... Fry's, Radio Shack, etc...
Belkin® F5D5050 Ethernet-to-USB Adapter
Model:
F5D5050' Catalog #: 55009874
Cannot connect to the internet wireless or wired.
If the problem is there both wired and wireless, the problem is then narrowed to your computer's modem/nic device. Speak with a Laptop repair tech about replacing this bit of hardware. When did you lose connection with Internet? Recently or long ago?
CD ROM STOPPED W0RKING
more than likely it went bad but check all your drivers for this hardware. go to start> my computer right click on my computer then go to properties on the drop down and click on it then go to>hardware>device manager and find the cd rom click the little plus sign on it and find troubleshoot icon that is all i can offer.
No Audio Driver Detected
have a compaq presario v2000laptop.The problem i have is it does not have a audio in it. can anyone help me reinstall the software so i can play and hear music on my laptop again. HELP PLZ.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
