20 Most Recent Pramac Diesel Generator 5500 Surge Watts, 5000 Rated Watts, Model Questions & Answers
5000s diesel will not start even on ether
mmost engines have a low oil switch. if generator is not level or it is low oon oil by just a little it will not start hope this helps bob
3/4/2013 7:25:41 PM • Pramac Diesel... • Answered on Mar 04, 2013
Pramac px5000 plug stuck in ac socket
If the plug of your Pramac PX5000 generator gets caught in an AC socket, follow these steps: 1. Turn off the electricity to the socket.2. Wear insulated gloves for safety.3. Gently wiggle the plug while pulling it out.4. Apply a bit of lubricant if needed.5. Use insulated pliers to grip and pull the plug.6. If you cannot take it away, get help from an expert electrician to keep it away from harm or injury.
3/19/2024 1:25:41 PM • Pramac... • Answered on Mar 19, 2024
0answers
3answers
Pramac s5000 generator, Subaru engine. Using 110v, it burns up the motor that it is plug in to. Over voltage??
What's the output voltage? Only way to know is measure it
6/29/2023 1:57:10 PM • Pramac... • Answered on Jun 29, 2023
2answers
How Can I Fix Pramac 12k Battery Charger Failure Alarm
If your Pramac 12k battery charger is displaying a failure alarm, there could be a few possible causes:
  1. Check the voltage level of the battery: Make sure that the battery is at the correct voltage level and that it is properly connected to the charger.
  2. Check the charger connections: Make sure that the charger is properly connected to the power source and that the connections are not loose or damaged.
  3. Check the charger's fuse: Make sure that the charger's fuse is not blown.
  4. Check the charger's cooling system: Make sure that the charger's cooling system is working properly and that it is not blocked or damaged.
  5. Check the charger's electronic board: Make sure that the charger's electronic board is not damaged or malfunctioning.
6/19/2023 1:41:47 PM • Pramac... • Answered on Jun 19, 2023
Pramac generator no power
Based on the information provided, it seems that the generator is producing voltage but not delivering it to the connected devices. Here are a few troubleshooting steps you can try:
  1. Check the circuit breakers: Make sure the circuit breakers on the generator are not tripped. If they are, reset them and try again.
  2. Check the connections: Ensure that all the connections between the generator and the devices you are trying to power are secure and not loose.
  3. Check the voltage regulator: The voltage regulator controls the output voltage of the generator. If it is faulty, it may not be allowing voltage to pass through to the connected devices. You may need to have it tested or replaced.
  4. Check the automatic voltage regulator (AVR): If your generator has an AVR, it may be malfunctioning and preventing power from reaching the connected devices.
  5. Check the capacitor: While a visual inspection may not always be enough to detect a faulty capacitor, it is worth checking it with a capacitor tester to make sure it is functioning properly.
  6. Check the wiring: Inspect the wiring for any signs of damage, such as frayed or broken wires. If you find any, you will need to repair or replace the affected wires.
If none of these steps resolve the issue, you may need to consult with a qualified technician to diagnose and fix the problem.
3/19/2023 3:12:08 PM • Pramac... • Answered on Mar 19, 2023
2answers
How do you change a solenoid on a p6000s generator pramac ?
My Pramac p6000s fuel pump won’t work off the key but will if a put it straight to live on battery any ideas thanks
5/10/2022 5:42:14 PM • Pramac... • Answered on May 10, 2022
Why is my generator shutting down with fault code 'over rev'?
Contact them direct. This is an undocumented error. The obvious thing to do would be to reduce the engine speed? https://www.generac.com/service-support/faqs/home-backup-error-codes/rpm-sense-loss-code-1501-1505-1511-1515 https://www.pramac.com/learningcenter ..
5/1/2022 8:25:40 PM • Pramac... • Answered on May 01, 2022
Pramac 6000 generator cuts out after 60 secs Temp light and oil light comes on but plenty of oil in it
possible defective oil switch. see your manual
1/30/2021 5:11:02 PM • Pramac... • Answered on Jan 30, 2021
I require the valve clearance gap for a pramac p6000s diesel generator
If you need data of valve clearance gap of the diesel generator, you can check on the operation and maintenance manual. If still can not find, try to ask your supplier whom supplies the diesel generator to you. If you need to have a generator set in future, please refer to www.dieselgeneratortech.com.
1/6/2020 2:57:39 AM • Pramac... • Answered on Jan 06, 2020
Pramac px 5000 generator gets hot cuts out?
The air duct is blocked by dust and the ventilation is poor, which makes the heat dissipation of the generator difficult. The dust and oil dirt in the air duct shall be removed to make the air duct unobstructed.
12/21/2019 1:46:11 AM • Pramac... • Answered on Dec 21, 2019
Pramac electric start generator. Where is the choke, gas cut off, what is on/off switch in upper right of panel for?
Please see the operation manual. If you have plan to purchase a new diesel generator set in future, please visit at www.dieselgeneratortech.com
12/5/2019 7:35:15 AM • Pramac... • Answered on Dec 05, 2019
2answers
We have a pramac genset equipped with a AC03 controller and time to time in AUTO mode it changes alone to MANUAL mode. Please, can anyone help? Best regards. FGaspar
You can changes to Auto mode. Some generator has auto mode and manual mode. In generally, emergency generators have these two actions, when power grid is cut off, the generator will connect to machine automatically, then supply power to the machine. If you need diesel generator set or more support, please visit at www.dieselgeneratortech.com
10/12/2019 1:01:44 PM • Pramac... • Answered on Oct 12, 2019
Pramac Diesel generatorGSW 65 &GSW 80,in both generator we are facing problem that make them shutdown automatically and message displayed is SD AMP unbalanced? what should i do to solve the problem?
I don't know your equipment, but the unbalanced term may refer to too large a load connected to one leg of your split phase service. Go to your load panels and try to get the amps drawn by your loads to be more equal. You may be over taxing one leg and have available capacity on the other, assuming you are running a 110/220 V split phase output.
3/15/2019 12:22:27 AM • Pramac... • Answered on Mar 15, 2019
I have pramac ac- 01 it running 1 mit after shoving dynamo alarm then engine stop
website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
2/8/2019 11:52:00 AM • Pramac... • Answered on Feb 08, 2019
3answers
Portable generator head stopped making power
portable generator head stoped making power engine runs fine sircut brakers are fine
1/29/2019 6:20:56 AM • Pramac... • Answered on Jan 29, 2019
How can solve stop failure alarm on generator pramac 20kva?
by finding the problem --check oil and circuits
12/11/2018 1:56:09 PM • Pramac... • Answered on Dec 11, 2018
2answers
Pramac diesel generator p4500 was running then stop how can i tell if any diesel in the pump
Crack open an injector line.
11/12/2018 3:12:02 PM • Pramac... • Answered on Nov 12, 2018
Pramac Diesel Generator 5500 Surge Watts, 5000 Rated Watts, Model Logo
1 questions posted
Top Pramac Electrical Supplies Experts
littlewheel
Ngoro
john h
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Pramac Electrical Supplies
Most Popular Question
5000s diesel will not start even ether
  • Electrical Supplies
