20 Most Recent
Kohler Replacement Engine Part Pa-22537 Ch13s Pitt jenny Questions & Answers
Kohler ch13s will not start{backfires]. But some times after many trys it will start and run find
I had this puzzler too! Turned out the problem is caused by the fuel-bowl needle valve. It may look OK but looks are deceiving. It gets a coating on the tip that causes a poor seal ... poor enough to allow fuel to flood the engine after a short run time. The flooded engine dies, but restarts OK after a delay that clears (cooks off) the excess fuel that flooded/killed the engine. SOLUTION: Remove the needle valve and carefully wipe and clean the tip with a white cloth soaked in solvent (gas is OK). The cloth will show the deposits that cause the problem. Carefully re-install the needle valve and float parts, start the engine, confirm that it runs OK and continuously. Simple fix .... puzzling problem.
1/19/2015 12:44:50 AM •
Kohler...
Answered
on Jan 19, 2015
Kohler 5ecd generator giving high battery voltage alarm
Fault code is displayed if the engine starting battery voltage rises above 16 VDC for a 12 VDC system or above 30 VDC for a 24 VDC system for more than 2 seconds when the engine is not running. This fault condition does not inhibit engine starting. The fault condition clears when the battery voltage returns to a voltage within the limits for more than 2 seconds
Check the battery rating and condition.
10/12/2022 2:42:21 PM •
Kohler...
Answered
on Oct 12, 2022
I have a kohler 5E generator has SPARK only on one side
Kohler 5e Marine or mobile/Generator??????
working on this lacking a meter and manual. ?
working blind I call it. not good that ever. call for help:
it has 2 coils, 2 sparkplugs 2 HV wires to fail, (1 of them)
and 2coil igniter
we use and ohmeter to the bad coil.
primary is of coil (ignitor end) is about 5 to 12ohms. (infinity bad)
secondary coil is high ohms 1000 to 10000, par, infinty bad.
the HV lead is used to measure secondary to coil core metal
the HV lead can fail too. making coil useless.
and last a bad ignitor ,
the 2 coils are same P/N so can be swapped and if failure move to other plug, bingo for bad plug , otherwise bad ingnitor box.
9/20/2022 2:15:49 PM •
Kohler...
Answered
on Sep 20, 2022
Kohler House Generator powers up when our electricity goes out but then powers right back down?
That is an engine running issue, not a battery issue. :>D The first thing to check would be fuel supply. Can you start up manually and keep it running. If you can, it is the contactor that senses your loss of mains power and switches the generator on. It is not maintaining the connection, or is is misdiagnosing the power from the generator as power from the mains.
8/31/2022 11:40:03 PM •
Kohler...
Answered
on Aug 31, 2022
