20 Most Recent
Labtec LCS 2422 Computer Speakers Questions & Answers
No sound right speaker
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
dont forget to vote
hope this helps
What's the part number for the operational amplifier ,DC 15dc of LCS 1024
why not photo the IC, and show that.
for 10x better answers.
not told what car is came out of or what the OBJECT did. (PCM/ECU/BCM ,etc?) <<< vast on cars/trucks\
many PCB or Modules the ICs are some or all , contract parts
and the number on top is secret contract Part number.
ahhhhhh it is not a CAR at all it is
LABTEC LCS-1024 AMPLIFIED COMPUTER SPEAKERS
moving you now to computers stuff
Can you hook up a Labtec 2424 sub to a smart TV
If you are looking for the top security companies in London that provides its customer with remarkable security services. Check out this site for security services https://www.urbansecurityguards.co.uk
