20 Most Recent
Compaq SoundBlaster 16 PNP Sound Card Questions & Answers
I have comp presario v6500.when
Please be
informed that any Driver software depends upon the PC make, Motherboard type
and Operating System. You need to know all the three information's to do get
going.
Please find the Driver software's of your Audio and video inside the
installation disk provided with the PC at the time of purchase. As you have not
mentioned your the Operating System you are using, I am unable to give you the direct download link. However
you can download the same by visiting the website of the company that
manufactured the PC.
Even here
you need to be careful to download the correct software for your PC. You need
to be exact with the PC make and Model number and the OS that you are using.
To install
just Double clock on the driver setup.exe file and go on clicking 'Next' until
you get the 'Finish' option and restart the PC.
If you feel that my answers have helped you getting
solution to your problems then please give a vote.
Thanks
5/27/2011 6:39:07 AM •
Compaq...
Answered
on May 27, 2011
No audio output device is
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
4/11/2011 10:32:04 PM •
Compaq...
Answered
on Apr 11, 2011
My audio driver is not
I would try the web site driverguide.com and fill out a free
registration search the data base for your driver download and install
the reboot your computer
1/22/2009 11:49:54 AM •
Compaq...
Answered
on Jan 22, 2009
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
