20 Most Recent
Creative Labs System Pull Creative SoundBlaster Live Sound Card CT4670 Questions & Answers
Please help
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
I need driver for ct4670 sb card! tnx!
1st Download Driver from this site
Creative Sound Driver
Installation of Sound Card.
- Go to the control panel
- Click on the System Icon
- Click on the Hardware Tab
- Click on the Device Manager then
- Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
- Right click on Multimedia Controller and uninstall it.
- After this go to the top of the device manager and click on scan for hardware changes.
- Driver installation Wizard start.
- Brows Your Driver from the Hard Disk and click on next.
- Driver will be install
- if the problem is still exist.
- Replace the sound card or have a local tech take a look at the sound card.
Windows7 driver
try the NGO modded drivers for creative sound blaster or audigy cards from:
http://www.ngohq.com/home.php?page=Files&go=cat&dwn_cat_id=20&go=giveme&dwn_id=20
click agree and file will download....
