20 Most Recent
D-Link DSM-G600 (DSMG600) Network Storage Server Questions & Answers
If i press the reset
Here is user manual that explains about this d-link. Network storage servers are just enclosures that you add a hard drive to to be able to use it on network. per this d-link manual all the reset button is supposed to do is reset network storage its self. I would read on it a little just to be sure. Hope this helps.
I can not see my
For that connect your d link router computer lan port with ethernet cable.
Then you can access it with http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then go to wireless and enable wireless .
Then save and restart router.
IF you can not able to access it then reset router.
You can reset it with RESET button it is in back side of router press it for 10 seconds so all settings goes to factory defaults.
Let me know if you need more assistance.
Thanks.
Wlan light not on
try this italian guide for 604/624 models :
http://www.darkshock.altervista.org/forum/viewthread.php?forum_id=25&thread_id=3
Good Luck
D-link DSM-G600 Wireless Enclosure I need the admin password
While running - press and hold the reset button for 10 seconds.
I needed to press firmly before it worked.
You need a paperclip.
Reset button is placed between network and usb connector.
After this you may login with username admin and blank password.
NB! Does not delete any data.
Problem Accessing Shared Folders in Network Stoarage Device
vista is only going to complicat things, try re mapping the drive, delete the shortcut and use my network places to find the drive then make a new shortcut to it if you can access it from there, i've had windows 2000 do the same thing especially with my laptop that I take to school, it a lot of times its due to changing ip's but occasionally windows just seems to forget where stuff is on the network and needs to be reminded. shortcuts can be made by draggin the folder to the desktop or desired location or right click the share you want mapped and select map network drive.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
