20 Most Recent D-Link DSL 300G+ (DSL-300G+) Modem Questions & Answers
2answers
Wont hook up
I don't think it's your server; it sounds like you need to change your network settings so you get your IP address from a DHCP server; it sounds like you have a static address and possibly your computer's IP address is the same as the server.
2/24/2018 5:19:16 AM • D-Link DSL 300G+... • Answered on Feb 24, 2018
Actually involves a D-Link DSL 300G Modem. Loses
This is common issue with the D-Link modems. There is a firmware update released by D-link.
Download the firmware update and install. It should fix the issue.
Download Firmware
Let us know if it fixed the problem
* Please rate this solution and comment on it
11/13/2010 3:38:01 AM • D-Link DSL 300G+... • Answered on Nov 13, 2010
2answers
We keep getting dropped for known reason .
Your internet modem needs to be reset to find the router first. The modem will find the first address when rebooting the entire system or if something gets unplugged..
I've had great success doing the following:
First of all turn off ALL computers, routers, modem ...everything... Then connect power to the main routing source... usually you've got your modem plugged into this.. Just start the router first with all ethernet cabling etc disconnected. Then secondly, connect power to the modem... As the modem connects, it will find the router ip address first... then you are set to turn on the wireless, and the other computers... and the router should designate proper ip addresses for all the peripherals and keep them connected without dropping someone off to allow the other address on... Hope this is clear.... So first the main router, then the modem followed by everything else... Let me know what happens ... and if you need more help...
9/8/2010 12:13:38 AM • D-Link DSL 300G+... • Answered on Sep 08, 2010
0answers
Will my DSL 300G Modem work
it will work if the subscription would also be an adsl line. but you need to know the new providers settings including type of connection (pppoe, dhcp, etc) and the vci settings. once you place the settings correctly, it will work.
11/6/2009 11:02:13 AM • D-Link DSL 300G+... • Answered on Nov 06, 2009
The internet connection keeps disappearing.
Change the router's IP address to (192.168.10.1) maybe you have an IP conflict between the modem and router.
3/16/2009 1:15:33 AM • D-Link DSL 300G+... • Answered on Mar 16, 2009
2answers
Slow downloading
the porblem seems to be at your ISP.
you need to check with your ISP and verify wha is your upload and downlaod speed. most of the time you should have 5Mb upload and 10Mb download as min.
the speed you are seeing is more like a dialup 133Kb.
2/14/2009 8:36:21 PM • D-Link DSL 300G+... • Answered on Feb 14, 2009
Dlink router 300
your routers ip shoulb be 10.1.1.1 with a netmask 255.0.0.0.
7/29/2008 6:04:25 AM • D-Link DSL 300G+... • Answered on Jul 29, 2008
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
1/3/2008 3:17:22 PM • D-Link DSL 300G+... • Answered on Jan 03, 2008
Modem and router fault
hi conway192,
your probally trying to access the router with the direct IP, try using the default gateway IP[the one that ends with 0's or 1's
to get the default gateway IP:
goto connections, right click local area connection, click support, then details.
Hope this helps.
jeremy
12/29/2007 9:17:57 PM • D-Link DSL 300G+... • Answered on Dec 29, 2007
D-link DSL-200 driver for windows 7 download
Guys who want to Download cheap Microsoft office 2016. You can click: http://microsoftkeydownload.blogspot.kr/515293381991299/ . All relevant key Microsoft Office on this, absolutely genuine.
5/27/2016 2:58:23 AM • D-Link DSL... • Answered on May 27, 2016
My internet light on dsl 2730u glows red.....
Contact your telephone-number and ask for the "Help Desk" for support for your DSL modem.
2/2/2015 5:32:52 AM • D-Link DSL... • Answered on Feb 02, 2015
Why wireless not working with my smart phone but the laptop via wire?
Probably because your home network (by which I mean your modem/router) is not wireless (WiFi). That's also why you have to "wire" your laptop to your network with an Ethernet cable, instead of using it wirelessly.
12/31/2014 8:24:25 PM • D-Link DSL... • Answered on Dec 31, 2014
Router 8 digit pin number
Should be on label posted on bottom of device..
9/13/2014 3:39:41 PM • D-Link DSL... • Answered on Sep 13, 2014
0answers
0answers
0answers
Wifi setup
Be the first to answer 8/15/2013 6:59:55 AM • D-Link DSL... • Posted on Aug 15, 2013Be the first to answer
D-Link DSL 300G+ (DSL-300G+) Modem Logo
15 questions posted
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DSL D-Link
  • DSL D-Link
Most Popular Question
actually involves d link dsl 300g modem
  • Computers & Internet
