20 Most Recent
D-Link DSL 300 Modem Questions & Answers
The D-Link Modem will not stay connected for
Is your unit old or new? Basically, there could be other factors giving you that intermittent disconnection from the internet. One is your ISP's internet connection that could be intermittently cut, or your browser refresh rate. Check out this two before you can conclude that the router is the problem. First change your browser to Mozilla Firefox. We had experienced the same problem with Google Chrome and IE not too long ago. If all browsers behave the same, then try to ask your ISP regarding your DSL issue.
D-Link DIR 300 router - Status LED and router doesn't work
Hi! I have a D-link DIR 300 wireless router.. I have the same concern before. what I did is, I did the hard reset by pressing the reset button for 20secs and after 20secs and the reset button is still press, I unplug the power from the back of the router and after 2secs plug in while reset button is press and press it for 30secs.. after that I unplug the power and plug in after 15secs. It should work, then u need to setup again the router in order to talk to the modem, if not.. and the device is still under warranty it needs to be replace...pls call your router manufacturer for replacement or if its still under 30 days, go to the store were u purchase the router.
I have been getting terrible download speeds. I am
Hi! your modem is a dlink dsl 300, if the modem is connected directly to your computer and you are only getting a speed of 60kbps..there is a chance that there is a problem with the modem.
this is the feature of ur modem:
Features
- ANSI T1.413 issue 2 (Full rate DMT over analog POTS)
- G.dmt (ITU-T G.992.1)
- G.lite (ITU-T G.992.2)
- G.hs (ITU-T G.994.1)
- G.lite ADSL: Downstream data rate up to 1.5Mbps. Upstream data
rate up to 512Kbps.
- G.dmt: Downstream data rate up to 8Mbps. Upstream data rate up
to 864Kbps
- Supports G.hs, a handshaking protocol at start-up to negotiate
and identify the operating mode for the DSL
- Supports a wide range of DSLAM's for inter-operability
- Complies to the T1.413 issue 2 standard (includes cable gauges
like 24AWG (0.5mm) and 26AWG (0.4mm))
- RFC 1483 IP over ATM
- RFC 1483 Ethernet over ATM
- Supports bridging/DHCP, classical IP over ATM, PPP over ATM,
and Embedded PPP over Ethernet
- 1 RJ-11 port for ADSL connection
- 1 RJ-45 port for 10 BaseT Ethernet LAN connection
- 1 Console (RS-232/DB9) port for local configuration
- SNMP management agent base MIB-enables other processes to provide
statistics and other information to remote management applications
- TFTP : The built-in Trivial File Transfer protocol provides firmware
upgrade and configuration backup and restore
- Telnet provisioning
I this modem is supplied by telus you have to inform them about it so that they can replace this modem right away... and this is a discontinued product from dlink.
Can,t access modem
disable all the fire walls
turn off all the security soft in urs pc
rescet urs modem 1s
then
try connecting the d link with the perfect jack to the perfect conector
thank you
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
