20 Most Recent Belling DB90 Electric Kitchen Range Questions & Answers
I've the same problem and been looking for a replacement control facia for 12 months. I had no luck so I went to www.sail-rc.com and purchased number graphics for a couple of pound.
Belling DB90... | Answered on Sep 14, 2014
I have just been able to get hold of my Aunt & Uncles manual and have quickly uploaded a pdf version to my website - 2.79mb - here is the link, hope this will help you all -
http://www.pierrequevatre.com/Belling_db90_Electric_Cooker.pdf
Belling DB90... | Answered on Apr 27, 2010
Open the doors 90 degrees to the oven front, then look just above the pivot point / hinge on the doors, there is a little plate with a screw (one above each door) - loosen the screw and slide the bracket towards the middle of the oven - you can then lift and take the doors off their pivot points - the inner glass will then slide up from the bottom and out for cleaning - once done put the glass back correctly, the bottom is marked so it is put back correctly - make sure you locate the doors back correctly top and bottom and then slide the plate back to prevent the door being able to lift out while in use and tighten the screw back up.
Hope this helps you all.
Just found this out while @ my Aunt & Uncles - the manual did not make it very clear at 1st.
I am looking for an electronic versionof the manual so I can print them a larger A3 copy as their eye sight is not what it used to be and they get lost while trying to read with a magnifying glass.
Tip
Common faults with Belling DB90 Range
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling DB90 Electric Kitchen Range
Try taking the cover for the fan and element off -- I found this is the only way of getting a decent grip on the glass. It's four Philips screws. Obviously make very sure the oven's properly cold and isolate the electricity supply before you do it!
Belling DB90... | Answered on Aug 26, 2009
There could be a few different things wrong. The element may have died. Is the fan you mention the forced air fan? No heat usually means blown fuse or faulty heating element, and since the small oven works I would suspect the the element has blown. You would benefit from getting an appliance serviceman to make a house call to replace the element. Unless you're handy and have a soldering iron, some heat resistant sleeving, and can access the back of the oven comfortably.
Hope this helps. Let me know.
John
Belling DB90... | Answered on May 09, 2009
You will have to change the orifice to accomodate lp gas.
Belling DB90... | Answered on May 08, 2009
if the clock is not set the ovens wont work,they dont have to say the right time but they do have to have a time. to set the clock hold the hand button and the clock button(first two buttons),and then plus or minus to set the time
Belling DB90... | Answered on Feb 05, 2009
New temp regulators req'd
Belling DB90... | Answered on Jan 27, 2009
Make sure timer is set to manual and noit auto
Belling DB90... | Answered on Dec 15, 2008
no clue here I would call a local repair service personally
Belling Kitchen... | Answered on Mar 21, 2019
Belling DB90 Electric Kitchen Range Logo
42 questions posted
Top Belling Kitchen Ranges Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Belling Kitchen Ranges
Most Popular Question
39 t read dials oven controls numbers
  • Kitchen Ranges
