20 Most Recent
Dell DVD-ROM for Dimension (6t903) Internal DVD Drive Questions & Answers
Flashed rom - now DVD
Click start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x right
click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
Replacing Dell Dimension 4600 Internal DVD Drive
1. make sure the connections are tight.
2. restart ur system..on dell logo press f2 key..
3. once in the bios screen...press num lock caps lock and scroll lock..make sure all 3 are on
4. press alt and e together
5 press alt and f together
6. press esc
7. select save changes and exit
ur system will restart...it should make the dvd rw get detected
Replacement DVD-Rom has video but no audio
You should be able to get sound thru the IDE cable (this is the same type of cable also referred to as a ribbon cable, your hard drive connects in the same way) that is connecting your drive to the motherboard. turn the pc off and unplug power and reseat this cable on both ends be careful as the pins are fragile and will break
if this doesn't fix your problem let me know and we will try anotherr solution
Dvd cd rom not reading anything on my Dell computer
Having to use a paper clip instead of the eject button working could indicate a power source problem. Not reading anything on the drive could be either power source, connection cable or motherboard. I would start by removing the drive and checking all connections. You did not state if this is a laptop or desktop. If it is a desktop, there should be several unused power connections.If you do not have the ability to check the used connection, just switch to a different one.Also check the connection cable to the motherboard and if possible change or replace that. If all this fails, I would assume from a distance that the DVD drive is defective and try to replace it.
External DVD Drives
Sorry to dissappoint you , but this not a possiblity.What you can to instead is copy the content of the DVD into a USB flash drive , and plugin the flash drive to your 4600c and install it from there.
A normal DVD reader writer drive , retails for not more that 65$ , so you can buy one two, more over local computer stores also keep refurbished drives, that you can get a good deal on.
Thanks
Mandeep
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
