20 Most Recent
Belling 644 Electric Kitchen Range Questions & Answers
Oven door opens by itself during cooking
could be the peg that engages into a double roller set inside the door. this peg is usually adjustable. try screwing it out a bit. also check that the spring tensioned roller is ok - these commonly fail
Belling Format cooling fan
i assume you mean the casing fan and not the fan inside the oven.
this is controlled by a fan stat which is inside the casing. cheap part and easy to fit. iv forgotten the exact location but remember it located at the top
Belling format
probably the fan jammed with crud but could be a faulty fan motor. remove the back panel inside the oven and the fan is exposed. try giving it a flick to see if it rotates freely. if no joy then the fan motor needs replacing. faily cheap part and not too hard to fit
Belling e297
You would need a 6mm twin and earth cable about 2 mtrs in length connections need to be made following the manufactures instructions. only attempt if you deem yourself competent. I guess if you need to ask the question perhaps you should get an electrician.
Trips out electric
check the wireing on the oven supply line check the breaker it may bu too small or week check ehere the cord is attached to the range most of the time this is where the promblem is
