20 Most Recent Dell POWEREDGE 2400 Server Questions & Answers
2answers
My server is working fine but is beeping continuously. How do I stop this beeping?
Sounds like a memory stick issue.. Try removing 1 mod at a time to see if it stops.
6/14/2015 2:40:27 AM • Dell POWEREDGE... • Answered on Jun 14, 2015
It doesnt reconize my cd rom at boot and is not
Enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
3/20/2014 12:16:17 AM • Dell POWEREDGE... • Answered on Mar 20, 2014
0answers
2answers
It does not want to start and is making a lot of
i would advise you service the machine and check the hard drive....
7/2/2011 6:40:17 AM • Dell POWEREDGE... • Answered on Jul 02, 2011
I am try to do
Please elaborate on your problem.
If you are trying to install from USB, you first have to enable the USB in the BIOS.
Older models of Dell PowerEdge servers does not support the USB function. It is all dependent on the mother board.
11/10/2010 1:44:19 PM • Dell POWEREDGE... • Answered on Nov 10, 2010
0answers
Does dell power edge server support hyper-v ?
yes
1/12/2010 9:15:47 AM • Dell POWEREDGE... • Answered on Jan 12, 2010
2answers
Dell PowerEdge 2400 - Fatal
I would read thru the following :
READ THIS
7/17/2009 4:45:34 PM • Dell POWEREDGE... • Answered on Jul 17, 2009
2answers
Do you have Dell PowerEdge
no but i have worked on them before...
4/29/2009 9:15:52 PM • Dell POWEREDGE... • Answered on Apr 29, 2009
2answers
Dell PowerEdge 2400
I have one for sale at www.JonRosenSystems.com. This is an extremely large and heavy unit. It has two P3-733 CPU's, 512mb RAM and three 18gb Quantum Atlas SCSI drives. I have more drives and RAM available.
1/14/2009 4:03:46 AM • Dell POWEREDGE... • Answered on Jan 14, 2009
2answers
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
7/29/2008 8:51:22 AM • Dell POWEREDGE... • Answered on Jul 29, 2008
No Boot device available Press F1 to reboot
Computer not recognizing the hard drive. Look in BIOS to see if hard drive is listed. Reload system disc/CD.
3/14/2016 4:54:22 AM • Dell PowerEdge... • Answered on Mar 14, 2016
2answers
I t will satrt up an run but computer keep shuiting down
It could be a couple of things 1. the computer Cpu fan is not working or is clogged inspect it and clean or replace.2 The power supply could be bad
6/14/2015 2:48:41 AM • Dell PowerEdge... • Answered on Jun 14, 2015
Power is 2950 i912 sel full
Namrata_stha, The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ } Where with Server 2003 you can go tot he Event viewer and clear it. Let me know if this helps.
10/1/2014 4:05:30 PM • Dell PowerEdge... • Answered on Oct 01, 2014
Configure remote start
www.hp.com/support
8/18/2014 7:10:29 PM • Dell PowerEdge... • Answered on Aug 18, 2014
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
8/8/2014 5:00:58 PM • Dell PowerEdge... • Answered on Aug 08, 2014
Dell poweredge t105 freezes at boot
You will have to get into the controlled setup in order to find out what the problem is, or you can simply hit ctrl-D and do the Dell disk diagnostics which will take an hour or more, but will give you an idea of where to start. Logically, if it won't boot, then your RAID is probably broken. it can sometimes be repaired through either the RAID or controller setup menu, which you can see during boot. go here, for the manuals and documentation on how to do that: http://www.dell.com/support/home/us/en/19/product-support/product/poweredge-t105/manuals
6/4/2014 8:25:56 AM • Dell PowerEdge... • Answered on Jun 04, 2014
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
4/4/2014 2:12:18 PM • Dell PowerEdge... • Answered on Apr 04, 2014
Dell POWEREDGE 2400 Server Logo
Popular Tags
17 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
am try
  • Computers & Internet
