20 Most Recent
Dell PowerEdge 400SC Server Questions & Answers
Install win 7 on 32 bit machine
Upon loading, there is a selection prompt. Select 32 bit configuration. There is also a Win 7 which is 32 bit, use this one if you have it.
System memory changed
you can hit F1 if it stops there on bootup and acknowledge the change or you can log into Open Manage and acknowledge the memory change there as well.
No audio driver
You can download the drivers from Dell WEB site, thesupport download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows XP or Vista version of the drivers for your Windows operatingsystem. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
My Dell PowerEdge 400SC server seems to run OK but
hello..this is the solution if u want to go back run properly the unit.remove the memory card SDR,DDR1 or DDR2..try to clean all pin connector using the paper eraser.Good Luck..Thanks and GOD DAY..^_^
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
