20 Most Recent
Dell Inspiron 8200 Notebook Questions & Answers
Hard-disk #44w4z2y3764-595B the system primary
Here is your Dell Hard Disk Master Password for HDD serial #44W4Z3Y3764-595BYour HDD Master Password is: w2cuzkedWhen asked for HDD Password use the HDD Master Password to unlock the HDD password. The Dell HDD Master Password is what Dell can calculate for you or a third party. Thanks to the great guys at
unlockbiosrecovery.com for providing the HDD Master Password that will unlock your hard disk. They can unlock your laptop bios or hard disk.
MY LAPTOP DELL INSPIRON 8200 SCREEN LIGHT KEEPS
It can be 2 things: Or the screen is dying, or the graphics card is dying. Try to start up with an external screen and see if it still blinks. When its still blinking on the external screen, your graphics card is dying, if the external screen shows no issue, then your screen is dying.
Return my dell-inspiron to factoy settings
Boot up with a Dell Recovery CD to format your hard disk and install a fresh copy of Windows on your laptop.If you do not have a Recovery CD for your model laptop then you can get one from the Dell WEB site. You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Dell inspiron 8200 error code
Could you please provide the details of the error code, such as the numbers that appear that relate to the error code. Thanks
I have a used Dell
Severe corruption. Since you can no longer boot in any way in it it's going to be extremely hard to fix it. Better just reinstall Windows from scratch. Use the recovery cd that should have come with the laptop. If you don't have it then just use a disk borrowed from a friend and the key on the label.
I have a Dell Inspiron 8200. The mouse does not
you can get some really cool tiny little mouse these days or even one with a ball on top that you rotate,ive got an optical one on my standalone,its got a cable but its pretty smooth.
But first try to configure the touchpad in your settings,thaths the most likely problem that you can most probably fix yourself
Power supply making a noise
Generally, the AC adapters make no noise, so if it is making a buzzing sound I'd replace it. They should be available on Ebay
I have problem with my usb not recognized.
go to the website and locate where you can download drivers/software, once you have done that look for the specific area and download the driver, or you can go to device manager and make sure the driver is working properly
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
