20 Most Recent
Dell Latitude CPX-J Notebook Questions & Answers
I got a dell latitude cpx and want to take it back
Just use the recovery disk that came with the laptop. Put it in, restart the pc and at the first image that appears you will be asked from where you want the pc to boot: select the dvd. After that it's pretty much automatic.
I have dell latitude cpx j laptop it has problem
this is happening only if the windows genuine advantage has found the xp not genuine..and blocked with that banner the functions ...in this case better reinstall and I will recommend this windows ..
http://thepiratebay.org/torrent/5388204/Windows_Xp_Genuinesadownload it with utorrent program ...and you need to have a Nero installed or another ISO burner..and just double click on the image to burn it on a CD-R ...after that boot from it and install...the key is in the folder ..write it down cause you will need it on installing ..
Please dono forget to rate ...Have a nice day ..
My headphone jack is broken on my Dell Latitude
It is a mecanical problem, not in settings. The laptop's headphone jacks have builted-in switches that disconnect internal speackers when the headphone jack is plugged in. You need to replase headphone jack with a new one or manually desactivate the swith - must to get ino your laptop and have skills in work with soldiering iron
What hard drive can i install
Any PATA 2.5'' disk will work. The problem will be in finding one since they are no longer produced in large numbers. If you're in US get one here http://bit.ly/dsOdjv
How do you take
on the bottom of the laptop there should be four screws un screw those and take the cover off next take the keyboard and top covering off then carfully remove the hard drive which should be loacted near one of the fans.
Dell laptop cpx
It is possible to reformat the system and reinstall Windows.
Adding Extram RAM and replacing the motherboard is not cost effective as you could buy a better system for the cost of the parts.
Suspend To Disc
try running DELL Diagonostics
run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave fn key
it will start running a diagnostic
let me know if you get any error or if you are able to see any video on the screen.
How to fix my dell E4310 from freezing while im using it?
There are a number of reasons that the unit could be freezing up.
- Corrupted file(s)
- Low available disk space
- Viruses and/or malware
- Too many add-ons/toolbars/etc.
- Heat build-up
Number one is the hardest to find. So start with #2. The computer needs free hard drive space to operate. If the disk is nearly full or is very fragmented, this can slow the machine to a crawl. Check for available space and if there is plenty (20GB or more), then check for fragmentation under administrative tools. If the defragmentation tool recommends optimization, allow it to perform it and see if that helps.
For viruses and possible malware, run your virus scanner. It is always a good idea to get a second opinion on such things. Malwarebytes is a free malware scanner that works very well to find adware and some things that many antivirus programs fail to detect.
Many user feel that they have to have every bell and whistle. I've seen some browsers with 7-10 different toolbar add-ons. These almost always come with some adware and always slow down the browser. Uninstall all but the most essential toolbars for the best performance. Heat is a slayer of machines. Laptops are very susceptible to heat issue since they are often placed on beds, sofas, carpets, and yes, even laptop. Many of these units draw cooling air from the bottom and exhaust it to the side. Even those that draw air from the rear and exhaust to the side will often intake large amounts of dust, grit, and lint. These can partially or completely clog the heat sink unit and cause heat buildup of the processor. This will cause the processor to work slower and can actually cause it to thermally lockup, resulting in the need to reboot. Many units can be accessed to clean with a removable cover on the bottom; others may need to be serviced by a technician to clean.
My latitude will not power up. I have a good power
no PC told , at all, model not told
ok generic mode.
1: huge battery inside is bad, shorted remove it , even for ever.
2: run on AC power only now.
3: push power button 10 full seconds release, ,runs now?
4: no, remove all USB devices now. run now?
5: no, coin cell battery dead, , replace it , run nolw
6: no. strip the PC down to find the shorted model.
lap-strip-101
https://www.pcdied.com/Dead_screens/dead-LT.html
Can you hard wire power to laptop?
NO
if you do, a noob will blow it to kingdom come. as in letting the smoke out.
the power-pack does 3 things
it has the correct DC voltage and wattages
and #2 prevents fire when the PC fails and things short inside.
and prevents huge damaging surges landing inside the PC
buy used power pack off fleabay and win.
i bet I'd mow one lawn and and buy one
