20 Most Recent
Dell Latitude CS Notebook Questions & Answers
Format a dell latitude cs laptop
hi rashmi
first g o to bios setup and check your external dvd is detected .
If not detected in bios then enable legacy 2.0 in bios advanced option then go to boot option and save first as dvd drive.
then uc an boot with it.
Let em know
Dell laptop, over 10 years old, don't have password, or the admi
If you don't care about the current files and folders, you'll need to reinstall the OS from the disk. I assume you have it. Pop the CD into the drive and power off the laptop then power it back on. It should boot to the CD and give you the option to reinstall the software. If not, power cycle (off then on again) and press F12 repeatedly as it powers up. This will give you the option of what to boot from. Choose the CD drive and start the install process.
If you don't have a disc to reinstall from, your last option is some password recovery software. You can google that for options, but I have nothing to recommend as I've not had occasion to use them.
Please rate my answer accordingly if you feel I helped you out. Thanks for using fixya.com
How to fix my dell E4310 from freezing while im using it?
There are a number of reasons that the unit could be freezing up.
- Corrupted file(s)
- Low available disk space
- Viruses and/or malware
- Too many add-ons/toolbars/etc.
- Heat build-up
Number one is the hardest to find. So start with #2. The computer needs free hard drive space to operate. If the disk is nearly full or is very fragmented, this can slow the machine to a crawl. Check for available space and if there is plenty (20GB or more), then check for fragmentation under administrative tools. If the defragmentation tool recommends optimization, allow it to perform it and see if that helps.
For viruses and possible malware, run your virus scanner. It is always a good idea to get a second opinion on such things. Malwarebytes is a free malware scanner that works very well to find adware and some things that many antivirus programs fail to detect.
Many user feel that they have to have every bell and whistle. I've seen some browsers with 7-10 different toolbar add-ons. These almost always come with some adware and always slow down the browser. Uninstall all but the most essential toolbars for the best performance. Heat is a slayer of machines. Laptops are very susceptible to heat issue since they are often placed on beds, sofas, carpets, and yes, even laptop. Many of these units draw cooling air from the bottom and exhaust it to the side. Even those that draw air from the rear and exhaust to the side will often intake large amounts of dust, grit, and lint. These can partially or completely clog the heat sink unit and cause heat buildup of the processor. This will cause the processor to work slower and can actually cause it to thermally lockup, resulting in the need to reboot. Many units can be accessed to clean with a removable cover on the bottom; others may need to be serviced by a technician to clean.
My latitude will not power up. I have a good power
no PC told , at all, model not told
ok generic mode.
1: huge battery inside is bad, shorted remove it , even for ever.
2: run on AC power only now.
3: push power button 10 full seconds release, ,runs now?
4: no, remove all USB devices now. run now?
5: no, coin cell battery dead, , replace it , run nolw
6: no. strip the PC down to find the shorted model.
lap-strip-101
https://www.pcdied.com/Dead_screens/dead-LT.html
Can you hard wire power to laptop?
NO
if you do, a noob will blow it to kingdom come. as in letting the smoke out.
the power-pack does 3 things
it has the correct DC voltage and wattages
and #2 prevents fire when the PC fails and things short inside.
and prevents huge damaging surges landing inside the PC
buy used power pack off fleabay and win.
i bet I'd mow one lawn and and buy one
