20 Most Recent Konica Minolta Bizhub C552 Copier Questions & Answers
Replace the IH Power supply, it will solve your problem... Page 71 Item 5 from the parts manual.
Konica Minolta... | Answered on Sep 09, 2018
Because there is a problem with tray four so it makes it disappear First open tray four remove the paper that might be stuck behind it.. Then enter service mode utility/counter, touch details on the meter count, then stop 00 stop 01 then select system 1, then select problem unit isolation, then select tray 4 your going to unset follow the screen, then your going to do the same process again this time set, if the draw continues to not show after this procedure get a tech out to look at it, as for tray three maybe the rollers need replacing have the tech look at them to.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Jan 10, 2016
Located under the control panel. Right side front cover. looks like a power supply. connects to the fuser,
Konica Minolta... | Answered on Dec 29, 2015
The IH power supply is located below the operational panel behind the front cover below the op panel,
Konica Minolta... | Answered on Nov 22, 2015
Have you changed the fusing unit? If try that first, then relace the IH Power supply or the (coil unit) is what the fuser attaches to when you install one. power supply is located right side under the control panel, .
Konica Minolta... | Answered on Nov 14, 2015
behind the right side cover under the control panel
Hey jrf, the manual says to check, in this order; proper fuser installation, proper closure ( door latch ) of the right hand door, check around-all around-for wiring connection issues, change fuser, then coil, then IHPU, then PRCB, then REDB. If you have a trade-in, or lease return, at the shop; it might pay to do some parts borrowing.
Konica Minolta... | Answered on Sep 23, 2015
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Konica Minolta... | Answered on Jun 14, 2015
again please explain?
Konica Minolta... | Answered on May 25, 2015
need a developer or turn off press stoop button and turn on :) (it's a truble reset )
Konica Minolta... | Answered 3 days ago
you just turn it off at the main switch (or unplug from the outlet), wait 10 seconds and turn it on to reset the temporary user initiated lock out.
  1. if the tray cannot be opened the emergency open latch is via a hole on the rear of the large capacity tray. stick in something till you feel the lever, push it and the tray should open. If the tray for some reason (usually user error) has lifted all the way up and the drawer cannot open, well, your going to need a technician and an open checkbook.
Konica Minolta... | Answered on Apr 20, 2019
check the assy under the transfer belt that slides above the front and rear id sensors is working, the arm can snap so the sensors can not see the belt.
Code
C-2302
Description
The EM signal shows an abnormal condition when a specified period of time elapses after the cleaner cooling fan (FM5) turns ON. This abnormal condition recurs when a specified period of time elapses after FM5 is turned OFF and then ON again.
Causes
Cleaner cooling fan (FM5) ADU drive board (ADUDB) Printer control board (PRCB)
The code indicates that the fuser is not turning for whatever reason.............. Do the following if it resets the code great, if it comes back it's probably the sensor on the fuser that detects rotation I think its PS-47. They have had problems with the mounting plate but at any rate at that point it would be time to call your servicing entity.
1. Turn OFF the main power switch.
2.Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
3.Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, wait 10 seconds and fire the machine back up, this should reset the service code and with any luck the machine will run!
  1. However, minolta-qms, Inc. makes no warranty of any kind including, but not limited ... Image Transfer Roller Cleaning 63 Image Transfer Belt Cleaning Mechanism 64 ... TAKE-UP SECTION 71 Manual Feed Tray 71 Lower Feeder Unit (Option) 72 ... 1 Do not unplug or plug in the power cord, or perform any kind of service or ...
Drive system home sensor malfunction
• The scanner home sensor is unable to detect the scanner located at its home position. • The scanner home sensor is unable to detect a scanner even when the scanner motor has been driven to move the scanner over the maximum travelling distance. • The scanner home sensor detects the scanner when the scanner has moved the maximum travelling distance from the position, at which it blocks the scanner home sensor.
1 Correct or change the scanner drive (cable, pulley, gear, belt) if it is faulty. 2 Correct the scanner motor set screw if loose. 3 Adjust [Image Position Leading Edge] and [Feed Direction Adjustment]. 4 Check the connector between M201- REYB/SCAN PJ5 for proper connection and correct as necessary. 5 Check the connector between PS201- REYB/SCAN PJ8 for proper connection and correct as necessary. 6 Check the connector between REYB/ SCAN PJ2-MFPB PJ14 for proper connection and correct as necessary. 7 PS201 I/O check, sensor check REYB/SCAN PJ8-3 (ON) T-9 8 M201 operation check REYB/SCAN PJ5-1 to 4 T-12. 9 Change REYB/SCAN. 10 Change MFPB.
Konica Minolta Bizhub C552 Copier Logo
14 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
konica minolta c552 error c3b02
  • Office Equipment & Supplies
