20 Most Recent
Konica Minolta Bizhub 283 Copier Questions & Answers
Bizhub 283 trouble code 3423
if after this procedure code come back replace the fuser, attempt again machine my catch on fire that would ruin a perfectly good day
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and
check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
How to do a trouble reset
turn off the machine then hold utility counter down turn the machine on in the upper right hand corner of the touch screen you will see a black dot that means you can let go of utility counter then it takes you too trouble reset hit it it will have an arrow that points down to ok reboot machine
Clarified error code for bh283: C-0202
Solution ID
TAUS1103824EN* Solution Usage 1
Description
C0202 (Tray 1) error code.Traymight not rise and indicates "out of paper" soon after it has been pushed in.
Solution
CAUSE: Actuator (Lever) for the upper limit sensor is hit very hard by the paper tray when opening/closing the drawer, and the Lever breaks.Upper limit
sensor (PS12/PS22) is either not activatedby the actuator(generating the error codes) oris always actuated(generating the out of paper message).
<Parts Guide Manual: Page 13, 16>
SOLUTION: Replace the current Lever (p/n A1UD 5611 00) with the modified one (p/n A1UD 5611 01).
APPLIED PRODUCT
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
