20 Most Recent
Konica Minolta Bizhub 423 Copier Printer Scanner Questions & Answers
Konica bizhub 423 red light blinking
If the red light is blinking on your Konica Bizhub 423, it usually indicates an error or issue with the printer. Here are a few things you can try to resolve the issue:
- Check the display panel: The display panel on the printer should show an error message or code indicating what the issue is. Check the manual or contact Konica Minolta support to find out what the error code means.
- Restart the printer: Try turning off the printer, unplugging it from the power source, waiting for a minute or so, and then plugging it back in and turning it on.
- Check the toner: If the toner is low or empty, the printer may not function properly. Check the toner levels and replace the toner cartridge if necessary.
- Check for paper jams: Paper jams can cause the printer to stop working. Check the printer for any stuck paper and remove it carefully.
If none of the above steps work, you may need to contact Konica Minolta support for further assistance.
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
Good morning, my Konica Minolta 190f says:please call service 001,what will I do to resolve this
Error code 001 is a generic service call error, and it could be related to various problems within the printer.To resolve this issue, follow these steps:
- Power Cycle: Start by turning off the printer, unplugging it from the power source, and waiting for a few minutes. Then, plug it back in and turn it on again. Sometimes, a simple power cycle can clear temporary glitches.
- Check for Obstructions: Ensure that there are no paper jams or any obstructions inside the printer that may be causing the error. Clear any paper jams carefully if you find any.
- Reset Printer: Look for a reset button or a specific key combination in the printer's manual or documentation. Try resetting the printer to its default settings to see if the error clears.
