20 Most Recent Dell (2336V) Motherboard Questions & Answers
0answers
0answers
Dell owg 864
Be the first to answer 8/28/2012 5:30:25 AM • Dell (2336V)... • Posted on Aug 28, 2012Be the first to answer
2answers
Net bios password work around
There will be a back door password , password can reset for some model in dell platform.A BIOS password is a protection measure that can be used to stop someone powering up a computer system or making changes in some of the computers most sensitive areas. Many big name computer manufacturers such as Dell and HP lock the customers out of this area because they don't want the customer changing anything and potentially damaging the machine (which the manufacturer may have to warranty). However, when someone like a computer technician or hardware enthusiast needs to make some hardware changes to the computer, they will need to access the BIOS. Here are some methods to bypass or remove a BIOS password.
http://www.technibble.com/how-to-bypass-or-remove-a-bios-password/
http://repair4laptop.org/laptop_and_notebook_bios_password_reset.html
From here you can see few some lock code
7/25/2012 1:24:28 AM • Dell (2336V)... • Answered on Jul 25, 2012
2answers
Dell Motherboard/ OWG 855, what would be the
Intel Core 2 Quad Q6600 @ 2.4 GHz is compatible.
Good Luck
Mark
6/1/2012 9:57:59 PM • Dell (2336V)... • Answered on Jun 01, 2012
I need to reset the administrator password
Using hirans boot cd 10.4
and remove password
10/8/2011 5:32:31 PM • Dell (2336V)... • Answered on Oct 08, 2011
GET LOW BATTERY MESSAGE AND
the CMOS battery of your computer is depleted.. Try to change it to save your BIOS setup including your time and date setting.
5/26/2011 11:58:38 PM • Dell (2336V)... • Answered on May 26, 2011
Need to disable password via
Yes on a dell motherboard there is a jumper used to connect and disconnect a battery that is attached to motherboard. In order to clear a BIOS password you need to remove the jumper for approx 30 sec and replace to wipe the password.
4/18/2011 2:21:04 PM • Dell (2336V)... • Answered on Apr 18, 2011
2answers
What processors does a dell owg855 motherboard
Any socket 775 processors.
It was produced before the 45nm processors so it may or may not support those.
It will support the Core2Duo, Core2Quad, and Core2Extreame.
Examples of the mainstream processors shipped with the board are the E6600, E6750, E6850.
3/1/2011 6:19:34 PM • Dell (2336V)... • Answered on Mar 01, 2011
2answers
Windows installation is very slow
As a guess you are installing Windows 7. Yup it is very very very slow. ;-]
The first time I installed 7 I thought there was something wrong but that is just the way it works. XP or Vista will install in about 30-40 minutes while 7 on the same hardware can take 3-4 hours (or more).
No fix for this other than finding something to do while you wait.
1/20/2011 4:31:12 AM • Dell (2336V)... • Answered on Jan 20, 2011
DELL DIMENSION 2350 L'ADMINISTRACTOR IS LOCK
You can use Hiren's Boot CD to reset the administrator password. Download it and burn it on a CD. Boot from CD when computer starts up and go to Password Tools, and use one of the Windows utilities from there (you can choose from more: Password Renew 1.1, NTPWD, WinKeyFinder 1.73, Offline NT Password Changer 2010-06-27).
11/25/2010 12:22:34 AM • Dell (2336V)... • Answered on Nov 25, 2010
Dell 2.4 ghz , 30g
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
11/16/2010 12:10:34 AM • Dell (2336V)... • Answered on Nov 16, 2010
The local computer shop indicates
Yes is the short answer, repairs will probably cost more than the mother board is worth.
Have a good look at all the solder joints, is there a dry joint, looks like a blob of solder which is
hollow and a bit of wire poking through. If you can find one, re-solder it.
If not, you're into electronically testing each component
Depending on how old your current one is, will depend on whether you replace with like for like or decide to upgrade.
Your problems will be:-
1) Dell uses proprietary equipment, so the replacement will still need to be supplied by dell. Or get a second hand one.
2) It will need to be compatible with your CPU, RAM, PCI cards and HDD/ optical disk interfaces
Good fun, but a nightmare if you're not sure what you're doing.
An alternative is to buy a second had PC and put you current HDD in as a slave keeping the original as a master, even then you need to match interfaces.
10/8/2010 7:28:22 PM • Dell (2336V)... • Answered on Oct 08, 2010
I am looking for an upgrade video card and cannot
Here's the motherboard's specs. I copied this off of Dell's website:
Socket Type Socket - T (LGA 755)
CPU Support Pentium 4 from 631(3.0G) upto 661(3.6G)
Pentium D from 920(2.8G) upto 950(3.4G) and 955(3.46G)
FSB Support 800MHz/1066MHz
Chipset(Northbridge/Southbridge) NVIDIA nForce 4 SLI (NVIDIA C19/MCP 55)
Upgradable BIOS 4Mb Flash EEPROM
Memory standard 533 / 667DDR2 (240 pin)
Number of memory slots 4 slots (populate in pairs for dual channel)
Memory Modules supported 512MB, 1GB, 2GB
Max memory supported 8 GB (using 64-bit OS)
Audio controller Sigmatel 9227 on High Definition Audio Interface
Audio specifications 24-bit ADC, 24-bit DAC
7.1 channels
~90 dB signal to noise ratio (tested)
Expansion slots 2-PCIex16
1-PCIex1
1-PCIex8
3-PCI
Internal Connectors 1 - ATA100 channel (upto 2 Devices)
6 - SATA '' (3.0 Gb/sec, NCQ with compatible drives)
SATA RAID 0/1/JBOD supported
1 - FDD channel
3 - PWM controlled fan headers (with compatible fans)
2 - USB 2.0 (USB ports 8 & 9)
1 - IEEE 1394a
1 - Front panel (audio, PWR & HDD LEDs, PWR button)
Rear panel connectors 1 - 10/100/1000 Mbps Onboard LAN (RJ-45)
8 - USB 2.0
2 - PS/2
1 - Serial (COM)
1 - S/P DIF out (optical)
Physical Form Factor 7 - slot full sized BTX standard (12.6" x 10.5")
The motherboard is a proprietary model, probably made by Dell
Regards
Riztech
9/25/2010 7:14:17 PM • Dell (2336V)... • Answered on Sep 25, 2010
When booting I get an
try cleaning your keyboard of dust because dust causes static which can cause lots of problems to a computer or make sure that your keyboard connection is secure +control panel,computer management,device manager scroll down to keyboards if a yellow question mark?right click update driver
hope this helps good luck
9/7/2010 2:11:03 AM • Dell (2336V)... • Answered on Sep 07, 2010
Hi ! I have a Dell OWG855 motherboard with a
Yes, a 1024MB video-card would work, but what are you doing that would benefit from such a high-end video-card?
Are you trying to drive a high-resolution (1920-by-1280) monitor, at high frames/second rates?
Is your CPU fast-enough to support a high frames/second rate?
9/1/2010 3:14:57 PM • Dell (2336V)... • Answered on Sep 01, 2010
I have a Dell Inspiron 530 w/ an 0ry007
This system uses a PCI-E slot for its video (graphics) card. This is the perfect platform to accept a high end card that has dual DVI outputs, which allows multiple displays. You should change out the card that came with the machine, most PCI-e cards these days have the dual outputs and cost less than a hundred bucks. The dual output is a better way to go instead of an adapter.
7/28/2010 3:35:41 PM • Dell (2336V)... • Answered on Jul 28, 2010
The cumputer dosnt start up
dell sucks
you the old take battery out of the motherboard (when not connected) then brdge the terminals G
5/11/2010 1:35:07 PM • Dell (2336V)... • Answered on May 11, 2010
Need to know where power
they are already labeled on the mother board.
Just follow the labels written on the mother board and you will get the power switch.
Good luck,
3/28/2010 1:02:25 PM • Dell (2336V)... • Answered on Mar 28, 2010
Dell (2336V) Motherboard Logo
58 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
net bios password work around
  • Computers & Internet
