20 Most Recent
Dell C600 (002UH) Motherboard Questions & Answers
Power appears at the pc
could be damaged power supply try replacing it with similar or universal type from best buy or radioshack
3/2/2011 9:44:01 PM •
Dell C600...
Answered
on Mar 02, 2011
There is only 1 usb port on this computer, and Im
All USB sockets support that, it's in the standard. But for ease of use it will be better to use a hub. But because it's such an old laptop it will surely be an 1.1 type, and the speed will be very slow.
12/26/2010 8:14:36 AM •
Dell C600...
Answered
on Dec 26, 2010
My computer has no sound
After reinstalling/installing an Operating System you can lose the Audio Drivers or sometimes they just corrupt.. Try reinstalling the Audio Drivers from the disk provide with your P.C./Laptop. If you no longer have the disk just visit the website of the makers of your P.C./Laptop or Motherboard and download the Audio Drivers from there, after that install them.
Thumbs up please if this works for you, thanks.
8/26/2010 6:59:42 PM •
Dell C600...
Answered
on Aug 26, 2010
Dell latitude c600, battery not charging even
hi im josh in cebu phils.may i help you. friend try to check the small wire white near the batt.or check the connections if it is not shorted or disconnected. or try to replace new batt. good luck
8/10/2010 12:46:46 AM •
Dell C600...
Answered
on Aug 10, 2010
Ineed Bios dell E219542 ??
laptop motherboard for HP,DELL,TOSHIBA,ACER,IBM,SONY and so on brand which is refurbished for the good quality and the competitive price ,welcome you to contact with us by
[email protected]
5/15/2010 3:15:22 AM •
Dell C600...
Answered
on May 15, 2010
I HAVE A BIOS PASSWORD BLOCKING IT FROM LOADING UP
To get by this password you have to clear the CMOS. To do this open the case and take a look at the motherboard (system board). Find the lithium battery that backs up the CMOS. Adjacent to the battery holder, somewhere near, depending on the make of your motherboard, you will see a set of 3 or 4 small pins with a jumper cap across two of them. ( a jumper cap is about 4mm square & 3mm deep with a metal liner) Remove this jumper cap and place it on the other two pins for abou 10 seconds. This puts a ground on the reset leg of the CMOS chip and clears all memory. Return the jumpercap to its original position and boot-up. Pressing 'del' will get you into CMOS setup. Find and select "Load defaults". Press escape and choose "save changes & exit". Computer will now boot normally and will not ask for a password.
3/19/2010 12:00:47 AM •
Dell C600...
Answered
on Mar 19, 2010
Audio problem
1st of all you check the sound card driver is install in the system.and also know Manufacturer name .
- Go to the control panel
- Click on the System Icon
- Click on the Hardware Tab
- Click on the Device Manager then
- Click on the Sound, Video and Game Controller then
- See the Audio Driver is in the list.if it is available then
- Check the sound is it mute if it is unmute then
- Check the Speaker Cable it is inserted in the sound card
- If the problem is still exist then Reinstall the driver .
- Open the device manager and click on the Sound, Video and Game controller after this.
- After this Right Click on the Audio Driver the Click on the Update Driver and update diver wizard will start.and your driver will be reinstall if the problem is still exist.
- Replace the sound card or have a local tech take a look at the sound card.
You can download different type of driver from this site.
Download Driver
3/8/2010 6:57:26 PM •
Dell C600...
Answered
on Mar 08, 2010
Machine completely dead no life signs at all
It is very likely that during the transportation, a loose contact could have been created. Now whatever be the case, since it does not turn on at all, the Laptop will have to be opened and the motherboard checked. Get a good technician to check the board for you and with the appropriate tools, it is very likely that your problem will be solved.
All the best.
1/21/2010 11:50:16 PM •
Dell C600...
Answered
on Jan 21, 2010
DELL d600 model pp01l
If your motherboard traces are damaged, I would highly recommend replace the board. This model laptop can have considerably high current running through that jack and traces. if anything is weak it will burn through.
Or take it to a electronics specialist.
12/30/2009 8:35:51 PM •
Dell C600...
Answered
on Dec 30, 2009
CHARGING PROLEMS
Josh, There are several possibilites. Lets start with the easiest.
1. Are you using the original power cord? The wrong cord will heat the system up.
2. Does your motherboard fan come on?
3. did you upgrade from windows XP to Vista?
10/14/2009 11:00:53 AM •
Dell C600...
Answered
on Oct 14, 2009
I found out that the ventilation fan of my Dell
1st make sure that your warrenty has expired.
The unscrew ever visible screw on the reverse of the laptop.
there is a few hidden one there under stickers... You will see some more screws where your processor is, careful unscrew them, and your done. Was you cleaning your fan or replacing it?
Because your wire may have come loose connecting your CPU fan to the motherboard.
Best wishes.
-Tom.
7/14/2009 3:48:55 AM •
Dell C600...
Answered
on Jul 14, 2009
Wireless button
The wireless button is on the left side of the computer. It is just to the right of the audio connectors.
6/25/2009 2:14:02 PM •
Dell C600...
Answered
on Jun 25, 2009
System password
ok buddy seems ur r Getting a Blue screen Error well please do a dell pc restore.to do a PC restrore pressl the Ctrl+F11 key on the dell page .please follow the on screen instruction.
6/4/2009 5:35:38 PM •
Dell C600...
Answered
on Jun 04, 2009
How many gb hard dics support
Are your asking what size harddrive your motherboard can take?
If so then as far as im aware theres no limit, that ive heard of. Just as long as your hardrive is the same connection as your motherboard it shouldnt be a problem.
Let me know if ive misunderstood your question
4/10/2009 2:45:50 PM •
Dell C600...
Answered
on Apr 10, 2009
