20 Most Recent
Konica Minolta KONICA BRAND TN-211 BLACK TONER FOR BIZHUB C200 AVG YIELD 17500 PAGES AT 5 % COV Questions & Answers
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
Maintainance call display of konica minolta copier bizhub 211
Maintenance call? from your question it is not clear what is the error code.Please see if there is any code appearing besides maintenance call.Note the error code and tell me again so that i can help you.If it is C0500 or C0501 then press the stop button on the panel and restart the machine do not release the button until the code removes.
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
