20 Most Recent
Konica Minolta Bizhub C220 Color Copier/Printer/Scanner Questions & Answers
Malfunction detected on KONICA MINOLTA Bizhub C220 trouble code: C-371
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
The copier reads, "The ADF is currently not available." How do I fix this?
This is going to be a two step process:
With the machine on go to service mode. Select System 1, Problem Unit Isolation, Find ADF, Select Unset, (This next step ensure you wait ten 10 seconds between) Power off the machine, 10 seconds later turn it on.
Once ready to copy. Conduct the same procedure again this time select ADF select SET this time. Power off a ten seconds later Power on. If the problem keeps coming back have a tech come out. Btw, I’m available to help over the phone in case u need at
What is c -3723 error code on a konica c220
4. Check to make sure that [OK] is displayed and the it has been reset.
I'm facing an error code at the starup code c-3421 on konica c220. please help me what i have to do?
Bizhub c220
try unpluging unit to reboot if all fails reinstall software
