20 Most Recent
MidiLand MLI-699 Computer Speakers Questions & Answers
Where can I get a driver for my MLi 691H speakers? I am running XP.
The humming noise could be a earth loop problem.
This is caused by having the speakers/sub woofer connected to one power
point and the computer connected to a different power point.
To eliminate earth loop problems, connect both the speakers/sub woofer
and computer to only one power point. Connect all your equipment to one
power point using a power board.
My mli 699 speakers are
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Do i need a driver for these speakers to work?
Hi!
It is clear in your statement that your speaker is not working anymore. Consider opening it and then check the wiring inside the speaker if it has lost connection and solder it.
Otherwise buy a new one this will get raid of the problem completely.
Hope it helps..
Have a nice day!
I have no sound
Try downloading the audio codecs for that matter. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you.
Best regards
Powers supply
12 v 500 ma. Let me know if you need one but you can probably get something at your local Radio Shack.
