20 Most Recent
Barcoreality 6300 Dlc Digital Light Cannon Video Projector Lcd Reality 2 Questions & Answers
F35-WQXGA Barco projector Model number: R9023422 SN 2017320059 showing cirictal error at sart ip adress
If your F35-WQXGA Barco projector is showing a critical error at startup with an IP address, here are a few steps you can try:
- Check the IP address: Ensure that the IP address is correctly entered and that it matches the IP address assigned to the projector. You can verify the IP address by checking the network settings of the projector.
- Check the network connection: Ensure that the network cable is properly connected to the projector and that the network is properly configured. You can try connecting a different device to the network to ensure that it is working properly
- Check the projector's logs: The projector may log errors and events that can provide more information about the issue. You can access the projector's logs through the projector's web interface or by connecting to the projector through Telnet or SSH.
- Check the network settings: Ensure that the projector's network settings, such as the IP address, subnet mask, and gateway, are correctly configured. You can check the network settings through the projector's web interface or by connecting to the projector through Telnet or SSH.
- Check the network connection: Ensure that the network cable is properly connected to the projector and that the network is properly configured. You can try connecting a different device to the network to ensure that it is working properly.
- Check the firmware: Ensure that the projector's firmware is up to date. You can check for firmware updates on the Barco website or by contacting their support team. You can also try reinstalling the firmware to ensure that it is not corrupted.
- Perform a factory reset: A factory reset can reset the projector to its default settings and may resolve the issue. You can perform a factory reset through the projector's web interface or by connecting to the projector through Telnet or SSH.
Do let me know the result please.
Critical error is showing at startup
If your F35-WQXGA Barco projector is displaying a critical error at startup, it could be due to a variety of reasons. Here are some potential causes and solutions:
- Lamp Failure: The projector lamp may have reached the end of its lifespan, or it may have malfunctioned. Check the projector's lamp indicator to see if the lamp needs to be replaced. If it does, replace the lamp with a new one.
- Power Supply Issue: Check the power supply to ensure that it is functioning properly. Make sure that the projector is receiving the correct voltage and that all cables are securely connected.
- Overheating: The projector may be overheating due to a blocked air vent or dirty air filter. Check the air filter and clean or replace it as necessary. Ensure that the projector has proper ventilation to prevent overheating.
- Software Issue: Check for any software updates or patches that may be available for your projector model. Download and install any updates as necessary to resolve any software-related issues.
- Hardware Issue: If none of the above solutions resolve the issue, it may be a hardware problem. Contact the manufacturer or a qualified technician to diagnose and repair any hardware issues.
It is recommended to refer to the user manual or contact the manufacturer for specific troubleshooting steps and solutions for your model of projector.
Barco CLM R10 came to
Without the service manual and/or schematic how can you check for voltages out of range? Maybe the mfg can be of assistance?
How do these points equate to money?
No money ever!
There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun.
ADMIN Andrew
- Answers: 65,820 and not a penny per Answer.
Head over to
www.justanswer.com they pay lots of money because they charge for people to ask a question.
