20 Most Recent MidiLand MLi 691H Computer Speakers Questions & Answers
2answers
I have just been given a pair of MLi 691H speakers -
We have no way to know that.
9/24/2019 7:06:09 PM • MidiLand MLi... • Answered on Sep 24, 2019
0answers
0answers
0answers
Not playing sound on my computer but plays sound
the built-in speakers may have failed or you need to update drivers. please provide more details for us to follow up! what happen just before they failed?
12/20/2010 12:19:55 AM • MidiLand MLi... • Answered on Dec 20, 2010
2answers
Speaker power supply
Found power supply for MLI-691 H speakers
Output is 9vdc, 600 ma. center of plug +.
SUN 9
4/4/2008 10:59:51 PM • MidiLand MLi... • Answered on Apr 04, 2008
2answers
What power adapter do i need for MidiLand MLi 691H Computer Speakers??
I have no way to look that up for you.
9/24/2019 7:06:29 PM • MidiLand Audio... • Answered on Sep 24, 2019
MLI 168, are connected to
Hi
If no sound is coming from the computer, start troubleshooting your problem. Make sure both your computer and speakers are plugged in, have power, and are turned on. If the speakers are plugged in but do not appear to have any power, plug them into a different outlet. If you are using a power strip and this is case, replace the power strip. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
Once you have verified that you have power to your speakers, test the sound again. If you still do not have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8" TRS cable) is plugged into the green audio output jack on the PC.
. If you are using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you are using outlet powered speakers and have a working set handy, replace the non-working speakers with the working pair to test. If you still have nothing, let's move on to software. But one tip first: (for geeks and beginners)
If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. If you've been messing around in the BIOS, you may have disabled your on-board sound if that's what you're using. If you don't know what BIOS means, you probably haven't been there and can move on.
Go to your desktop. Click Start > Control Panel > Sounds and Audio Devices > Volume tab. If everything is grayed out, go to step 8. If the "Mute" box is checked, un-check it. In "Device Volume" make sure that your volume level is set to a comfortable volume level for your speakers.
Click the "Sounds" tab. Under "Sound Scheme" check to see if "No Sounds" is selected. If it is, click "Sound Schemes" and a drop down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. These will be indicated by a small speaker icon located next to them. Simply left click the sound once, then click the play button. If you hear sound, congratulations. If not, move on.
Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Try this fix for reinstalling drivers. Click Start > Right-click "My Computer" > select "Properties" from the drop-down menu > Click the "Hardware" tab and then click the "Device Manager" button. Device Manager will open.
Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers" If you have a red X, right click the device with the x and select "Enable" from the pop-up menu. Test your sound at this point. If you have a yellow question mark, right click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Now, click the button "Roll Back Driver" to go back to the previous drivers that were functioning correctly. Restart your computer at the prompt.
As a last resort, you can uninstall and reinstall the device. Right click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If after doing all of the steps, listed here and you still cannot hear any sound from your computer speakers, contact a qualified computer technician.
Also check the bellow link to troubleshoot your problem:-
http://www.ehow.com/how_2225072_no-sound-problem-computer-speakers.html
Please get back to us if you have further query else please accept the suggestion.
3/23/2011 5:51:11 PM • MidiLand Audio... • Answered on Mar 23, 2011
MidiLand MLi 691H Computer Speakers Logo
21 questions posted
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • MidiLand Audio Players & Recorders
Most Popular Question
speaker power supply
  • Audio Players & Recorders
