20 Most Recent
Avery Dennison Ave-2181 Filing Mini-sheet Label - 0.66" Width X 3.43" Questions & Answers
Personal Label printer looks like
Labels are a common cause of printer jams. As the label paper goes
through the printer, it is not uncommon for a label to peel off and get
stuck inside the printer. Even a small blockage like a label can cause
the entire printer to jam.
if u dont have warranty u can try this method..... if u have warranty dont hesitate to call avery
Inspect the roller for label pieces. Manually remove any pieces that are stuck to the
rollers. If adhesive residue builds up on the roller, please visit web site at
www.avery.com/labelprinter for cleaning instructions.
if the label is jammed The Status Light Indicator is RED
or will not stop flashing.
• Remove any jammed labels.
• If the feeder is clear of a jam or debris, press the
Advance button to feed labels.
• Turn the printer off and on.
High volume printing, 20 continuous labels or more,
may cause the Print Head sensor to pause printing if
the Print Head gets too hot. If this occurs, the printer
will automatically resume printing, within minutes,
once the Print Head cools down.
if that doesnt help....
• Press the Advance button.
• Lift the Peel Lever (up) and press the Advance
button.
• Make sure that the labels are rotating over the top of
the Spool (inside top door).
• Make sure that the label roll is properly feeding
through the Print Head Opening.
• Remove the roll and check for jagged edges,
shredding or jammed labels.
Check for jammed labels or a blockage of the label
feeder. make sure the print head is also clean...... agaion i must insist that u try opening ur label printer only incase ur warranty period is over.. opening the printer while ur warranty period is still intact will void ur warranty
if u found my adice helpful.... kindly rate my service........
thank you
good luck and have a nice day
I can't get Avery 8160
Its possible that you are trying to use software designed for windows XP or such, Vista will not normally work with earlier software. Check to see if there is vista compatable software available.
