20 Most Recent
Samsung Ln32d403 32-inch 720p 60hz Lcd Hdtv black Questions & Answers
I have LN32D403 32-Inch 720p 60Hz LCD HDTV sumsung
Hi there, unfortunately there can be a problem with power insufficiency... if you have two USB connectors side by side on the back of TV set , please use Y Usb cabel and connect both in TV set and the other end to HDD. Or if your HDD comes with external power supply ac adapter connect it first. Then try again.Tnx
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
on Apr 14, 2024
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described.
Here are a few options you might consider:
- Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
- Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
- Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
- Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
- Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM •
Samsung...
Answered
on Feb 04, 2024
Component units not displaying color
I think you need to check the color settings on your new LG TV and ensure all cables are securely connected. If the issue persists, you don't have further options except to contact LG support for assistance.
1/5/2024 8:10:23 PM •
Samsung...
Answered
on Jan 05, 2024
