20 Most Recent
Creda W100FW Front Load Washer Questions & Answers
Used non he detergent in front loading washer
That wont hurt anything but if you put a lot in you may have a suds problem. My whirlpool has a suds reducer that will take out the extra suds. I am not sure it yours has that set up or not.
Whirlpool 1000 w100 stops after filling with water
see this causes and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet
valve cold water side may have failed. Most washers have a cold water
rinse and so if they can't fill with cold water they just sit
indefinitely waiting for the cold water to enter. If there is cold water
to the water inlet valve and the cold water works in other parts of the
cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main
control board might be defective. This is not common. Check other causes
first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might
be defective. This part is often misdiagnosed, check other components
before replacing this timer
Blocked drain
Is there still water in the machine or have you bailed it out? Some units have a serviceable water pump, meaning you can take the bottom of the pump off and clear gunk that has plugged it up. When you manually turn the dial to spin cycle, does it spin and push any water out even a tiny amount at a time? If not, take a large bucket and then place it on the floor next to the machine and place the drain hose in it. The bucket needs to be lower than the water level in the machine. When you do this, does it drain? If so this would solve the issue of whether or not the pipes are plugged. If in both cases either on spin or with the hose lower than water level, if it only drains a tiny stream then you do have a plugged line and you would need to disconnect the hoses from the pump under the machine and clear the plug. Be prepared for a lot of water to come out when you take the hose off of the pump. The plug is most likely in the hose coming out the bottom of the tank going to the water pump. This item has the hose leaving the machine going to the house drain. The other large hose goes up to the bottom of the tank. Good luck and let me know if you need more help.
Door interlock
Probably blown a track on the timer pcb, you need to remove the timer to check for short circuit.
