20 Most Recent
TMI Products VizuaLogic 90A-79006-L563 BMW X5 2003 - 2005 Sand Leather Car Video Player Questions & Answers
BMW X5 fuel guage doesn't register
hi will, it sounds like one or both of the fuel sending units has failed. the sender on the passenger side is responsible for reading empty to 1/2 tank, and the one on the driver's reads 1/2 to full. if the passenger sender is stuck down or failed, it could read empty when the tank is full. the senders are a pain to install correctly due to the installation angle. I have even seen techs at the dealer install them and have to reinstall them. i would recommend having both of the senders tested.
Bmw x5 2003 central locking does not work
Hi
On one of my 2001 X5 car keys would not always work but sometimes did, so I knew that the central locking was ok it was key related, I decided before shelling out to the BMW garage I would dismantle the key and have a look. (you will need super glue, tape for this and a small knife), it
Hello my bmw 2003 x5 a/c and heater some times
Sounds like a common issue with X5s and other BMW cars--blower motor resistor. This part is in your dash behind the climate control. You should be able to find more info looking up "X5 blower motor resistor."
It is a reasonably easy fix for any DIYer
My 2001 BMW X5 doors wont open from outside
Hi
You may have broken the door handle inner component, which is a DIY job (£50 or so) you tube has a video on how to remove and replace the “carrier” it is quite tricky but can be done as I have on my 2001 X5 after a hard frost and hevy hands.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
