20 Most Recent
Epson AcuLaser C4000 Printer Questions & Answers
Our epson aculaser c4000 makes
Basically there is a grease on the inside of the film on the fuser, the film is a grey colour the orange roller is what is called the pressure roller. what has happened the grease has worn out. you can get buy one from this site which i have used many times
http://www.getprice.com.au/Epson-S053018-Fuser-Unit-220V-Compatible-with-AL-C2600N-2600N-80000pg-S053018-Gpnc_217--35190949.htm
Also if not you could try and re-grease the fuser film yourself for free
http://www.copierscopiers.com/store/Canon-Fuser-Film-FUSER-FILM-WITH-GREASE_p_64-469.html
this is the grease you will need but i couldnt find a site that sold the grease on its own.
i hope this helps
My colour is coming out pink- when I see yellow and
You need to replace ink, try to buy complete set of ink and replace it, if same problem in printing, try run self test print if default test page print in complete color, or else there’s problem with your print head.
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
