20 Most Recent
Epson Stylus Color 660 InkJet Printer Questions & Answers
My epson c59 says the ink cartridge is expended,
You may have a defective Epson cartridge
(internal ink level monitoring circuit) - Epson uses a piezo-electric sensor (in all their cartridges) that is subject to this type of failure...the cartridge may need to be replaced.
However, if after replacing the T0753 cartridge with brand new Epson Original ink
cartridge, does NOT correct the problem, then you may have a defective PRINTHEAD in the printer (i.e. permanent electrical sub-assembly which the cartridges plug into).For information
on North American ink refill services at a major retailer near you (should you
wish to save ~50% on ink costs), general printing problem/troubleshooting resolutions or advanced printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error
bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Epson Stylus color 660 - all lights (red and
Q:
Why are all the lights on the printer flashing?
A:
When all the lights flash, your printer
may have an internal error. Verify that all packing material has been
removed. Instructions for removing the packing material will be found on
a notice in the box. If the printer has not made any noises for more
than five minutes, turn off the printer. Open the cover and check for
any obstructions. Power on the printer to see if the error still occurs.
If the unit still gives an error, please contact the Epson Connection
for further assistance.
Set up but not printing ink even though has new
When the printer ink was replaced the maintenance key would not have been used. If so remove off the printer , reinstall and then connect the printer.Now on theprinter properties the ink levels will show correct. Now take a test print.
I have the 660 printing output data from my blood
please your printer page setup in go and select to colour printer
second you go the control panelt in select to printer open and go set the printer and colour print set and use the printer.
just you print aply when select colour and printsprieveu check and aply prints ok
Printing
Time for new printer, Printhead is clogged solid. Printhead is more expensive than the cost of a new printer.
Unable to change ink cartridge
Turn it on, when it goes from side to side, then quickly turn it off to the spot where it will allow you to open it. Then open the print cartridges and change them. Turn it back on.
Hope that helps.
Printer lights stay on
Hi geoger,
Can you give more detail about the lights and if they flash and in what sequence.
The most likely cause is that your machine has hit the maintenance error meaning that the waste ink pads are full.
This requires that the pads be cleaned/replaced and the counter within the firmware be reset. To do this, you will need the service manual for the 1290 to dismantle it and gain accesss to the pads and the software to reset the firmware counter.
You should be able to get these from:
http://www.TheServiceManualShop.com and/or
http://mikeburton.tradebit.com/
Red ink
Have you missed removing a piece of tape that covers a vent hole somewhere? This would stop the flow of that ink.
Printing pics goes to blue
Time a replacement me thinks unless your are upto doing a jet cleaning job.
take a look at www.fixyourownprinter.com
